What benefit upgrading from 4x4 to RS500 i/cooler ?
Old Dec 28, 2003 | 05:50 PM
Default What benefit upgrading from 4x4 to RS500 i/cooler ?
Is it worth me changing to a Radtec RS500 i/cooler, at present running 803's, 3 bar , 4x4 i/cooler,standard T3 turbo 18-2opsi (288bhp on rollers at flywheel). I will be changing the turbo for a T34 at some point, but would I get any benefit from using a 500 sized i/cooler at the mo rather than the 4x4i/cooler considering i'm only running about 20psi, do you think I would notice any difference in power ?
Cheers Simon.
Old Dec 28, 2003 | 09:49 PM
dave cos4x4's Avatar
dave cos4x4
Yes! imo.
I roughly have the same spec,changed to a pace rs500 i.c, and i could the difference.
You could then turn the boost up more!
Dave.
Old Jan 2, 2004 | 12:48 PM
Phil's Avatar
Phil
Jeebus
remember the 500 cooler blocks the radiator so your cooling system will need to be up to scratch!
Old Jan 2, 2004 | 06:29 PM
Thanks for the replies, Iv'e ordered a radtec 500 i/cooler, a friend of mine has now told me he had a lot of trouble fitting his radtec one to his 4x4 saph,he had to drill new mounting holes as he just couldn't get the rad to fit properly after cooler fitted. Do you know if a radtec one fits ok on a3dr with the standard rad. Re cooling system all Iv'e done is had the standard rad recored as it was weeping,the car has never overheated even in traffic jams such as ford fair sitting in traffic for 2hrs,fans all work correctly. Thanks for any info,much appreciated.
Cheers Simon.
Old Jan 2, 2004 | 11:27 PM
dave cos4x4
Don't know about the radtech ones, but the saff have holes already there so they bolt straight on!!
Good luck fitting!
Dave.
Old Jan 4, 2004 | 01:33 AM
XR4Timan's Avatar
XR4Timan
This is very interesting. I thought a Stg 1 Cos gets btwn 250-280hp. I'll be getting a 4x4 IC soon and I was contemplating a Stg 2 upgrade (803s, chip, 3bar, 18-20 psi). After the 4x4 IC i guess i'll get a 3" exhaust system - try to make the most of my Stg 1 setup first.
Might just save up for an another engine before I go for the extra Stg 2 bits, eh? Whatcha guys think?
Old Jan 4, 2004 | 10:10 AM
just go straight for stage 3 and then you only have to spend the money once
if ur engines a bit tired i would give it a look over first though
Old Jan 4, 2004 | 08:27 PM
dave cos4x4
Dave.
Old Jan 5, 2004 | 11:11 AM
STUCOS's Avatar
STUCOS
I HAVE FORGE 500IN IN MY 3DR,AS STATED ABOVE,MOUNTING HOLES ALREADY THERE,REMEMBER THIS IS THE SAME SHELL AS A 500
Old Jan 5, 2004 | 09:37 PM
Thanks for the reply/info Stu.
Cheers Simon.
Old Jul 14, 2010 | 09:40 PM
r70at's Avatar
r70at
hi i have a standerd 3dr with a good spec t34 and it pulling 300bhp,get a good turbo.
andy
Old Jul 15, 2010 | 01:37 AM
jon@work's Avatar
jon@work
Old Jul 15, 2010 | 07:56 PM
wolf cosworth's Avatar
wolf cosworth
If in doubt ! Flat out !
Got a stage 2 but should that not be 22 to 25 PSI for a stage 2 I was told by MSD ? And I only get 18 to 20
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
Sp3no
Sep 27, 2015 07:23 PM
