If it goes hard ? 3door cosworth
The brake pedal on my cossie ? 3 door .
Drive it after starting everything seems ok , thn if i press pedal it goes hard
It does stop me put really need to munch down on it
Heard of a few things which it could be , but anyone no for sure ??? abs pump ?
Any help appreciated
It does stop me put really need to munch down on it Heard of a few things which it could be , but anyone no for sure ??? abs pump ?
Ex Full Price gold member
prob worth checking the fuse behind the bottom of the dash mate as mine went and did exactly the same pedal is rock solid i can't remember if it is the passenger side or the drivers side though sorry man.
HTH
Martin
edited to say i'm 99% sure it's passenger side
HTH
Martin
yeah mine went whilst giving it some beans one day for some reason it was ok at first then solid after 5-10 mins it took a couple of days before me and a pal chased it back to that fuse changed it and has been perfect since..
worth a check just in case really.
Martin
Martin
Originally Posted by cozzie_dave1
so where will i find this fuse cheers
HTH
Martin
Originally Posted by rabmc
Too right , my right legs out of proportion to my other leg now
And i pulled a hamstring too
i think it's the panic you have when you go to brake and there is fuck all there that frightened me the most
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
3dr cossie
21
Nov 20, 2015 05:00 PM
Aug 14, 2015 07:29 AM
