keeping car stored over the winter????
Old Oct 22, 2006 | 11:48 AM
winter's Avatar
winter
Default keeping car stored over the winter????
hello there im taking my xr2 off the road and its in my garage. ive put some old wheels on but is there anythink else i should do while its sitting there cheers.
Old Oct 22, 2006 | 03:26 PM
Gaz7's Avatar
Gaz7
Make sure the petrol tank is full. You can drain the other fluids, but if you're only storing it for the winter, you may not want to do this. If it's not going to be started, take the battery off, and keep it in the warm, inside you house
Gareth
Old Oct 27, 2006 | 08:46 PM
r44flyer's Avatar
r44flyer
Chock the wheels, don't put the handbrake on.
If it's easy to do so, turn it over every fortnight for 15mins.
Old Oct 29, 2006 | 10:57 PM
PT's Avatar
PT
why fill the petrol tank up? mines been away for month and a half now and is only half full, in a carcoon
Old Oct 29, 2006 | 11:00 PM
Gaz7's Avatar
Gaz7
When the car isn't moving (therefore the petrol is still in the tank and not being sloshed about) the fumes corrode the inside of the tank. If it's full, it's all liquid and no fumes, hence no corrosion
Gareth
Old Oct 29, 2006 | 11:09 PM
r44flyer's Avatar
r44flyer
There are also additives you can buy for the fuel that 'keep it good' whilst in storage.
Old Nov 2, 2006 | 07:22 AM
Series_One's Avatar
Series_One
Never heard of filling the petrol tank up! Just make sure you have additives so the petrol does not seperate.
Things I would recommend is listed below although I'm sure people have other tricks. This is only for short term storage ie over winter
1) Petrol additives
2) Leave the hand brake off
3) Over pressure the tyres to stop any flat spots
4) Ideally use a carcoon
5) Start every six to eight weeks
Old Nov 16, 2006 | 11:26 AM
winter's Avatar
winter
cheers for the tips much apreciated
Old Nov 16, 2006 | 11:57 AM
Gaz7's Avatar
Gaz7
Default Re: keeping car stored over the winter????
Just because you haven't heard of it does not make it incorrect
Fuel vapour is corrosive when it does not move for long periods of time - the full tank means it's a liquid and no vapour.
Gareth
Old Nov 16, 2006 | 06:09 PM
DAN P's Avatar
DAN P
escos fule tank is platic any way
Old Nov 16, 2006 | 11:43 PM
Gaz7's Avatar
Gaz7
Gareth
Old Dec 4, 2006 | 08:16 PM
crash_ash's Avatar
crash_ash
at the risk of sounding dim, my petrol tank is rarely full, and i'd say it has rarely been totally full for the past 16 years, and it's still sound, not doubting just confused.
i suppose if he tank was full there'd be no air in the tank, therefore water vapour couldn't condense and send the petrol wappy.
my head hurts, to be safe i'll pack my tank with waxoil.
Old Dec 5, 2006 | 05:10 PM
Gaz7's Avatar
Gaz7
If the car's being used it doesn't matter - the motion of driving disturbs the fuel in the tank enough so there's not a problem. It only becomes a problem when it's left to stand for long periods of time with no movement.
Gareth
Old Dec 13, 2006 | 09:48 PM
prwoodford's Avatar
prwoodford
teamwoodspeed
What additives are available to counter the issue of having a half empty tank whilst in storage? Any available at Halfords for example?
Old Dec 17, 2006 | 03:38 PM
Fro Turbo's Avatar
Fro Turbo
im gunna hav to keep my erst in my drive over winter and was wondering the best way to cover it? other than a carcoon...
cheers
Old Dec 17, 2006 | 03:51 PM
prwoodford's Avatar
prwoodford
teamwoodspeed
Anyone?
Old Jan 3, 2007 | 12:02 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
cheers
Get a quality breathable outdoor cover. My cover was from Specialised Car Covers and is an indoor tailored one, buit they do make outdoor ones as well. Not cheap, mine was Ł200 8 years ago but I use mine for summer only. My car is in a CarCoon now. Set of steelies on, brick either side of one rear wheel, no handbrake on, rear windows open for ventilation. Forget about her for best part of 6 months !!!
Old Jan 3, 2007 | 04:33 PM
Gaz7's Avatar
Gaz7
Prwoodford - i believe Redex make a suitable product.
As MrS1 said above, Specialised Car Covers make really good quality covers, as do Hamilton Classic
Gareth
Old Jan 27, 2007 | 07:17 PM
timturbo's Avatar
timturbo
what bout some of the ones of ebay anyone rate them?
Old Mar 22, 2007 | 02:26 PM
THE KID's Avatar
THE KID
put a small plate in your car fill it with salt this will take out any moisture in the interior
Old Apr 5, 2007 | 12:57 PM
cortinaman's Avatar
cortinaman
i wouldn.t chock the wheels or overinflate them, best thing to do is get the car off the floor all together and stand on axle stands.
original
Apr 28, 2026 05:20 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
