variable boost
Old Oct 16, 2006 | 03:09 PM
EssexAaron's Avatar
EssexAaron
Default variable boost
i would like to run a 12 point variable boost setup on my engine but have been told you can only run this with a 8 injector setup on my ECU (P8)
is this true? or is there someway around it.
i currently have air injectors controlling the boost
any info would be great
Old Oct 16, 2006 | 03:11 PM
Get the right boost controller and you can do what you want.
Why the hell would anyone want 12 settings though? you do know that the footpedal on the right can be used to vary engine output?
Old Oct 16, 2006 | 03:31 PM
EssexAaron's Avatar
EssexAaron
its hard on the map im running at the mo.. the air injectors bring it on boost really quickly.
Old Oct 16, 2006 | 04:01 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
That is correct about the four injector P8 with the MTC board .
I only have the boost control option, as mine is an 8 injector version. If you can wait until the end of the month, mine will be for sale with the Pectel loom as well... .
Old Oct 17, 2006 | 10:30 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as chip said, 12 point seems really silly. but that was the switch that was used back in the day, so that's what people still use.
in reality, surely 3 (low, medium and high) or 4 would be enough?
EssexAaron get in contact with RP Lab. they will be able to do the conversion that you want and allow you to run adjustable boost with only 4 injectors.
it's only said that it can be done with just 8 injectors, as that was done before by some people, and others can only buy the same stuff from the supplier. they're not clever enough to write the code themselves. RP Labs are however. they have many years experience with the P8 ecu writing custom code for it to allow many different inputs and outputs
Old Oct 17, 2006 | 11:12 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
why bother? thats what throttle control is all about, and the best thing is its free
Old Oct 17, 2006 | 11:19 AM
Stu @ M Developments's Avatar
PassionFords Creator
The 12 position boost pot is NOT designed to give you 12 positions of boost control people.
It was designed so to stay in the MIDDLE so that racers could adjust the boost to suit different atmospheric and humidity levels around teh world. Nothing really silly about it when used for its intended purpose.
Old Oct 17, 2006 | 11:26 AM
It was designed so to stay in the MIDDLE so that racers could adjust the boost to suit different atmospheric and humidity levels around the world. Nothing really silly about it when used for its intended purpose.
Indeed, just a waste of time in a road car.
Old Oct 17, 2006 | 01:42 PM
EssexAaron's Avatar
EssexAaron
ok... its just annoying running 1 stage boost
Old Oct 17, 2006 | 01:43 PM
hi/lo boost switch is all you need really on a road car i reckon mate
Old Oct 17, 2006 | 02:20 PM
EssexAaron's Avatar
EssexAaron
i cant use this on air injectors though.. only on amel valve
Old Oct 17, 2006 | 02:21 PM
Indeed, one of the many reasons i think air injectors are a load of old toss.
The other main one being the fail unsafe rather than fail safe.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
