Boost, pistons, fuel...
If a set of pistons are prone to melting at 14psi of boost on a T25 with a crappy interwarmer, would they still melt at 14psi with lower intake temps??
or say running less boost on a larger turbo with lower intake temps?
higher inlet temps lead to increased possibility of det, and less power due to less density.
It seems like your pistons can only take so much cylinder pressure, ie power. You can jiggle about how you make this power, but in the end you'll still be left with the same cylinder pressure's, or more correctly, work done on the piston.
your problem is the mangememnt lol
it can only fuel enough for 14psi max dangerously aswell, safer at 12psi
my mates went through this kept cracking number 3 piston even on fresh engine rebuilds etc
final engine build he had omex fitted and was the best mod ever to get rid of the crappy rover ecu
dont bother with these piggy back things either as its cheating death of teh engine, think it only lets you run more boost but doesnt give you fuel, as there is no adjustment for fuel anywhere on them
change teh mangement
melting is temptreture...
so lowering detonation causing factors (like crap fuel, high charge temps) will help.
Backing out a little timing would help too.
If they crack then you have found the limit of the pistons - anything else is more a setup issue.
Alex
Alex
problem is the t16 engine has no adjustment, fixed fuel, fixed timing
not even an adjustment for co as its all ecu controlled
honestly change the management to something that can be adjusted and you wont go wrong
plus you can also go coilpack aswell if you havnt already got it
but its fairly easy to build a low comp engine aswell using rover parts if you can find them
Originally Posted by James
Could you wire a 5th injector setup?
my mate had bigger intercooler water injection everything bar mangement and still blew up to lack of fuel at 14psi
rover ecu are shit
but change them and there a totally different car
Mark RS
Oct 12, 2015 06:01 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
