crank grinding
Old Oct 12, 2006 | 03:51 PM
demolition_man's Avatar
demolition_man
Default crank grinding
I've pulled the zetec crank out of the shed only to find surface rust on the journals. I've polished them up but i can still see pitting so what i need to know is am i better off getting this crank re-ground or just getting another crank?
Also what are the standard oversized bearing sizes, so that i can have the crank ground to the correct size.
bit technical - thanks for any advice
Old Oct 27, 2006 | 10:21 AM
cossieDavedree's Avatar
cossieDavedree
Default i know its a late reply
dont need to get a new crank mate, just take it to a local engineers
they'll polish it out, If they can't, they don't know what they are doing i had the same problem with a pinto crank which i thought was too badly pitted., They assured me they could polish it out without a regrind. they did .
Old Oct 27, 2006 | 12:44 PM
sailorbob's Avatar
sailorbob
Probably cheaper to get a second hand crank, they are common enough.
Old Oct 28, 2006 | 10:50 PM
jayRS's Avatar
jayRS
1.8 zetec cranks and 2.0 zetec cranks are the same so as above, common to get but a pain to remove, cranks can be polished so that prob ya best bet, prob be about £30 tops.
if ya wanted a regrind, to give you a rough idea, i had my FRST crank reground, cost me £135, and that included new bigs and mains and thrust washers, bargin i thought, but it depends where ya go.
DixieTheKid
11
Jun 6, 2020 11:20 AM
20/20 vision
Sep 29, 2015 09:25 PM
timsrs
22
Sep 24, 2015 08:14 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
