FITTING A NEW STUD ON 2WD SAPH COSSIE
Old Oct 8, 2006 | 11:27 AM
BAZZA BOY's Avatar
BAZZA BOY
Default FITTING A NEW STUD ON 2WD SAPH COSSIE
HI ALL, I have a 2wd saph cossie. My problem is, is that on the rear drivers side wheel a stud has broken in half. Could anyone tell me how I can knock it out and put a new one in. also is the disc mounted on the hub any other way apart from just the calliper and the wheel.
Any help would be great.
One other thing is that my abs light has just started to flash on and off every now and then (not all the time) is this just a faulty sensor or something worse.
Cheers in advanced
Old Oct 8, 2006 | 02:54 PM
cos47's Avatar
cos47
The studs just beat out mate, when you put the new one in make sure you get it square when it first goes in then put some large washers over the end and a smear of grease and pull it through by winding a wheel nut on . The disks are held on like you said .
Old Oct 9, 2006 | 09:51 PM
BAZZA BOY's Avatar
BAZZA BOY
Default cheers mate
thaks for that mate, much appreciated indeed fella
gcfcos
118
Aug 18, 2015 05:53 PM
155lee
Aug 14, 2015 11:21 AM
nice_head
Aug 12, 2015 07:01 PM
ray barker
Aug 7, 2015 09:00 AM
lockie
Jul 31, 2015 10:03 PM
