pipes or hoses(opinions whats best sierra 4x4)
Old Dec 27, 2003 | 01:30 PM
Default pipes or hoses(opinions whats best sierra 4x4)
Wanna hear the truth now.All in mine car are samcos,been told should be more flexible??Then somebody says,if you put pipe from t4 to intercooler you will have faster moment and i also now spec r doing pipe for intercooler to throttlebody,someone using them some dont,i am f..king confused.please tell me
Regards Alex
Old Dec 27, 2003 | 01:40 PM
big_wig_074's Avatar
big_wig_074
would have thought metal pipe would be better than silicon hoses as they wont crush at any realistic boost pressure and will have smoothyer internal surfaces.i think.
Old Dec 27, 2003 | 01:45 PM
if you use a more solid hose you will lose no pressure ! if the hoses are soft they can expand and use pressure .
i had all polished alloy ones made for my renault 5 turbo , i didnt really notice any difference but i never split another hose after having them made !!!
im using samcos on my 2wd and i personally think they will be fine .
Old Dec 27, 2003 | 02:00 PM
PJay's Avatar
PJay
I've got metal pipes, no problems from them at all at 23psi
PJay
Old Dec 27, 2003 | 02:06 PM
yeah thats it ! if u can afford the ally pipes go for them , they look superb and wont ever split ,
Old Dec 27, 2003 | 02:11 PM
Samco and hi grip jubilee clips seem ok on my T4 car.
Old Dec 27, 2003 | 02:21 PM
good point rude dude !
get some mikalor clips , they aint cheap but grip so much better than jubilies !!
thats where most people loose pressure from !!
Old Dec 27, 2003 | 03:25 PM
the original's Avatar
the original
what do these mikalor clips look like?
Old Dec 27, 2003 | 03:33 PM
they are about 3/4 of an inch wide , and instead of having a little screw to tighten them , they have a half inch bolt that goes thru a bar on the other side , which works basicly the same as a jubilee but a hell of a lot tighter .
Old Dec 27, 2003 | 03:37 PM
and there stainless steel so wont rust
Old Dec 27, 2003 | 03:43 PM
Phil's Avatar
Phil
Jeebus
rs500 hoses and normal jubilee clips worked fine for me, never lost a hose ever and was running well over 35psi
Old Dec 27, 2003 | 03:47 PM
Phil,i tried a RS500 throttle body side hose and at 34psi kept blowing it off until i used proper clips..but that caused it to split around the dump valve take off No probs with the samcos
Old Dec 27, 2003 | 03:49 PM
Phil's Avatar
Phil
Jeebus
saying that my throttle-body side hose is just like an rs500 but has a smooth finish and a part number stamped into it!? whereas my compressor side is a normal cloth texture finish!
very odd!
mines using ford jubilee clips and they actually seem very strong, but now everythings out its all going to have proper bling clips when rebuilt!
Old Dec 27, 2003 | 04:04 PM
extra17's Avatar
extra17
top quality clamps
http://www.powerengineering.co.uk/mikalor/
Old Dec 27, 2003 | 04:06 PM
i never had any probs with the cossi , but i was forever splitting and blowing off hoses on my r5gt so i use em with samcos as a matter of precaution now !
Old Dec 27, 2003 | 04:13 PM
if u like i can go take a photo of em and post it on here , so u can see what theyre like .
Old Dec 27, 2003 | 06:03 PM
spt the difference ?
Old Dec 27, 2003 | 06:27 PM
swerv's Avatar
swerv
mikalor clips
they dont cut into hoses either , worth while getting them imo
Roosie
11
Aug 22, 2015 10:13 PM
Vincereese
Aug 15, 2015 06:24 PM
cossie4x4
Aug 14, 2015 06:29 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
