ANY ONE HAVE COILPACKS FITTED TO THEIR COSWORTH .QUESTION
JUST ABOUT TO FIT COILPACK CONVERSION TO MY 3DR.
COUPLE OF QUESTIONS.
DID YOU HAVE TO DO AN ADJUSTMENT TO THE REV COUNTER AS IVE HEARD THAT IT WILL NOT WORK UNTIL IT IS DONE[WHAT DOES IT INVOLVE].
ALSOWHAT HAPPENS TO THE LEADS THAT ATTACH TO THE COIL[NOT THE COIL LEAD]DO YOU JUST TAPE THEM UP.
IF YOU HAVE DONE THIS CONVERSION OR HAVE IT ON YOUR CAR PLEASE HELP.IM GETTING IT ON WED.CHEERS MARK
Is it a SECS-designed board from MSD ? If so, then if it's a recent one, then the board will have been slightly modified to improve the rev counter output. If it is an early board, then a small mod is required to the board in the ECU (a wire needs to be cut and soldered to a transistor leg). You can either do this yourself, or send the ECU to MSD for modification.
Whichever SECS/MSD board it is, there is a mod required to the back of the rev counter.
There was a post in General Discussion about this by Stu@MSD about 2 months ago.
If the coilpack conversion is being done by fitting a suitably modifed P8 ECU or a different management system, then all of the above info doesn't apply.
With regards the original coil wiring, yes just tape the wires up.
YES THE BOARD WILL BE FROM MOTORSPORT DEVELOPMENTS.
ITS TO GO INTO MY LEVEL 6 ECU.
SO ARE YOU SAYING THAT IF ITS A NEW STYLE BOARD WHICH I THINK IT WILL BE THERE WILL STILL BE AN ADJUSTMENT TO THE BACK OF THE REV COUNTER TO BE DONE BY ME.IF THERE IS HOW INVOLVED IS IT.CHEERS MARK
yes there is still a mod required to the back of the rev counter
the pic below is taken from a document sent out by Stu@MSD and shows the required mod to the rev counter:
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 15, 2015 10:43 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
