various cossie bits going cheap
many parts for sale at bargain prices to get rid quickly prior to imminent house move. will be put on ebay if not sold on here first, but will fetch more on there than i have advertised them here for to give passionforders the chance of grabbing some bargains.
all prices are for collection from basingstoke or bracknell. postage on some items will be considered at your cost, depending on size.
Stg 2 chip (t3, 3 bar MAP, 803 dark greens) from Turbosports for L8 ECU with std babyboard £50 - makes 300 bhp at 1 bar boost @ 6000 rpm
Propshaft 2WD Cosworth T5 to 7.5" rear diff £75
Front Bumper £50 - in white with laguna splitter. reasonable condition, but has broken side mount brackets as usual and has been drilled through the sides to be fitted with bonnet pins
Dash dials (170 mhp speedo and C rev counter) £30
Front Brakes £500 - 330 x 30mm AP discs on gold anodised bells with modified 4 pot calipers and all fitting brackets and fasteners, pads (Ferrodo) and braided Goodridge hoses. Awesome brakes that retain std caliper piston sizes for pedal feel and travel, and wide range of pads available (although std pads have never faded on these on any track including the Nuerburgring). Bolt to any 2WD struts, and even fit behind RS 7 spoke 17" wheels.
https://passionford.com/forum/viewtopic.php?p=3226325
LHD dash £20 - complete with all panels (except clocks), glove box etc from 2WD sapphire in light grey with no cracking etc in good condition
2wd rear brakes £100 discs and calipers with goodridge braided hoses and nearly new pads. handbrake mechanisms in good working order.
2wd rear adjustable Koni dampers £50 - for the pair in good condition
estate rear motorcraft dampers £20 - non self levelling type, only 6 months old. modified mounts to fit either self-levelling or non self-levelling
2WD sapphire fuel tank £20 - without neck and locking cap
2wd cossie starter motor. genuine ford in good working order. £30
2wd header tank. usual yellowing, but solid with no leaks. £5
2WD cossie front hubs £40
2wd PAS pump and bottle and nearly new connecting hose £25
handbrake cable for 2wd cossie £5
"2wd header tank. usual yellowing, but solid with no leaks. £5 "
hehe looks like it has been shat in.and that is no usual yellow..hehe thats fookin burned ..looks like atleast.
Every time someone posts stuff for sale on here theres always a smart arse ready to pounce with a snide comment, keep them to yourself mate it only f*cks the guys post up
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
