headgaskets
whats the going rate to replace one?
ive been looking around and is there much point going for a wrc one over a group A one when running on stage 3?
how much is a good price for both of the above to retail at?
and apart from obviously the bolts and headgasket is it worth replacing the reast of the gaskets at the same time?
@ righthooker
right, woodford has reasonable prices. At European Ford Event I bought an 3 bar map, Weber Marelli, new, not used or refurbished for 90,-- €, that's 60,-- GBP. If this is not reasonable, what's than?
Best
Yours
Ronny
Best
Yours
Ronny
My Group 'A' headgasket lasted 10k miles on a stage 3 conversion. 1.7 bar of boost. I know of a genuine MAD built 400bhp cossie that never had a group a headgasket fail. Choice is yours as to weather you use a group a or a multi-layer metal one, but for the sake of Ł60 get a multi-layer one. Cometic will do fine, you dont have to buy the proper wrc one
Originally Posted by RonnyD
@ righthooker
Best
Yours
Ronny
Best
Yours
Ronny
Cometic headgaskets arent great IMO, for stage 3 go with group A head
set with a wire rung block
not easy with the bottom end in the car but
can be done, mine cost Ł80 to wire ring it and was done by Andy Fisher.
If you wanted a multi layered item go for the WRC one its a fit and forget
job but costs around Ł350 just for the gasket
@ righthooker
Best
Yours
Ronny
Best
Yours
Ronny
ok, you talked about h/g; my post with the map was for example, in Germany you can get an 4 - layer WRC for 132,-- GBP from SUHE - Motorsport, genuine one, no fake.
You lived in "Deutschland" for 10 years, so you know the difference between Germany and the UK getting part's for the FORD's.
Ronny
220TC
13
Oct 25, 2004 11:22 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
