How much boost are you running?
I send this question out to everyone.
How much boost are you or have you ran in your engines CVH or ZVH.
And what spec of head gasket and headbolts have you used.
I ask because currently I am having problems holding in 33psi.
So looking for peoples experiance on the subject.
Cheers,
Simon.
Cheers,
Simon.
Previus engine spec was 8.2:1 on std gasket and bolts with 29psi also no problems.
But upped the CR to 8.8:1 done more work to head and upped boost, it has blowen and deformed all 4 sealing rings.
Looks like I now need a copper head gasket and a wire rung block.
Long time no speak, seems we are both heading in the same direction!
Thats on a std gasket and bolts?
I do have an external waistegate spare however I have not inspected or rebuilt it yet, so I think you would be better off getting a new one, at least you know it would work and not let you down.
S.
S.
It has not been on the rollers since I built the new engine.
I can say that I remember what it felt like with 340bhp on the old engine and the new one feels so so much faster.
On my datalogger(Gotech) it takes 3 secs to run through 3rd gear.
S.
S.
Originally Posted by stuart collins
Originally Posted by turboboss
28psi on felpro head gasket and non Stretch head bolts what power are you aiming for running 33psi?
what is it a zvh?
si is a zvh using focus rs bottom end . mines a 1600 and im goin for 400bhp +gas
my 2.0zvh yesterday made over 400 on 28psi
400 plus gas on a 1600!! i also run nitrous going to be running 20psi plus 100shot, the kits all in just need to set it. what clutch will you be running.
JK12
33
Apr 26, 2021 12:09 PM
