TDC's or how to fit a block to a head?? anyone help??
Hi. Has anyone got any good websites or some good tips on how to find crank and cam TDC's manually or how to fit a head to a block properly Thanks
Only asking cos i built one the old school way of finding the highest point on piston 1. I then put top pulley to TDC and fitted cam belt with them both ligned up. fires lovely but theres just a slight catch i think of the valve catching the piston.
Basically my mechanic friend was with me and showed me how to do it. We turned the crank until piston 1 stopped. It was the mid point between getting to the top and dropping down again.(at the very top)
is this right???
also how do i determin the cam shaft istdc. I been told you can check with a screw driver in spark plug 1.
is this right???
thanks
is this right???
is this right???
thanks
What you did was have them ROUGHLY at top dead centre, you will never get it exactly accurate without the dial guage mate.
is this right???
is this right???
thanks
is this right???
is this right???
thanks
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
