anyone on here make bigwing sumps?
Old Sep 7, 2006 | 08:12 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Default anyone on here make bigwing sumps?
could do with a bigwing sump,i have one on order but its takin to long(short staffed so they not getting done at the moment) and would like one this month if possable? any takers?
Old Sep 7, 2006 | 08:18 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Pretty sure Marco does?
Old Sep 7, 2006 | 10:21 PM
wildheart's Avatar
wildheart
NMS
Old Sep 8, 2006 | 07:14 AM
Sticky.'s Avatar
Sticky.
Lee@Fusion
Old Sep 8, 2006 | 09:56 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i got mine via big MIKE R it came (sent mine to him first) in a week,no probs
Old Sep 8, 2006 | 10:16 AM
MAD EVO 4's Avatar
MAD EVO 4
Im sure Danny B could make you one
Old Sep 8, 2006 | 11:20 AM
the original's Avatar
the original
Al do you just need a normal cossie bigwing sump
or do you need one modded for escort old school as well
i have a sierra big wing sump you can borrow
Old Sep 8, 2006 | 11:26 AM
Might be worth PM'ing garage19, i dont know how often he does them but he did a fantastic job of mine for far less money than most people charge
Old Sep 8, 2006 | 11:32 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
is a bigwing sump the same thing as a baffled sump or are they 2 completely seperate things?
Old Sep 8, 2006 | 11:35 AM
Its like the name says rich, its got "wings" sticking out either side to increase the capacity.
Basically just two boxes welded on with a slot along the bottom (from the sump) to allow oil to move in and of course a hole at the top (back into the sump) to let the air out!
Old Sep 8, 2006 | 12:16 PM
CossieRich's Avatar
CossieRich
Cheers Chip,
Is this the sort of thing you need when using your car on track?
What does a baffled/gated sump do then?
Old Sep 8, 2006 | 01:33 PM
Retro Al's Avatar
Retro Al
RWD IS KING
im not sure m8 i left it up to the people who were sorting it,i belive it was supposed to be slightly differant to a normal bigwing sump so i dont need to modify the pick up pipe
ganna be getting my car back from pro alloy soon, so i wanted to get a sump on asap
Old Sep 8, 2006 | 01:39 PM
cressy's Avatar
cressy
have you tryed THE BIGWING SUMP SHOP.co.uk?mite be worth a try lol
Old Sep 8, 2006 | 02:53 PM
CozzyBrom's Avatar
CozzyBrom
ppl get mixed up which is wat
marco does or did do gated baffeld big wing sumps they are around £450
with a pick up pipe
i do sumps with 5 day turn around only with sump up front these are equal hieght side tanks
£180 deliverd and £20 each dash or sender plug fitting if needed
4x4 guys martoons ya man
the mountune baffle only stops oil surge under braking not corners adn costs nearly £200
makes my sump sound to cheap
jessie_rs
62
Aug 6, 2019 09:27 PM
155lee
Oct 27, 2015 04:55 AM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
