how to tell boost pressure
Old Sep 6, 2006 | 03:21 PM
RST Ski's Avatar
RST Ski
Default how to tell boost pressure
can you tell how much boost a car is running by looking on the boost guage and reving the car up?
Old Sep 6, 2006 | 03:28 PM
scottbrown's Avatar
scottbrown
no. really need to hold in 4th gear.
Old Sep 6, 2006 | 03:44 PM
John Laverick's Avatar
John Laverick
Doesn't need to be 4th gear...anything other than neutral will tell you.
Old Sep 6, 2006 | 03:48 PM
RST Ski's Avatar
RST Ski
so if i hold it at the revs the turbo cums in i should see the boost held on my gauge? but gota be moving
Old Sep 6, 2006 | 03:56 PM
stuart collins's Avatar
stuart collins
yep
Old Sep 6, 2006 | 04:27 PM
notSteveS2's Avatar
notSteveS2
foot to the floor in 3rd is normally easy way
while driving mate
Old Sep 6, 2006 | 05:24 PM
addiction's Avatar
addiction
the best way is to drive at 60 mph in 4th gear then floor the throttle
Old Sep 7, 2006 | 09:05 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
"Official" method.
- Accelerate up to 4th gear
- Pedal to the floor at 1500 rpm
- hit the brake at 3500 rpm, keep the throttle fully depressed though (not longer than 5 secs)
- read your gauge now
- let your brakes cool down
On my car (std actuator at the moment) it makes a huge difference, whether I'm in first, second, third or fourth gear. Don't know what it's like with an uprated actuator, though
Old Sep 7, 2006 | 12:08 PM
John Laverick
Whats all this holding in 4th gear and putting on the brakes business??
As far as I'm aware thats a technique a tuner will use when road mapping to avoid flying down the road at 120mph whilst mapping?
Surely everyone hits full boost in all gears? What difference does it make what gear you're in .
Just drive along....put you foot down and see what the gauge goes round to
Old Sep 7, 2006 | 12:17 PM
JesseT's Avatar
JesseT
No way. 1st and 2nd gear go so fast that the turbo has no time to really spool up. 1st will not even spin the wheels properly because of larger turbo. 3rd gear is still spinning wheels, so the full boost will not really develop. 4th will show steady full boost no problem.
Old Sep 7, 2006 | 01:32 PM
John Laverick
Must be different in a higher power car....I get full boost in 1st and 2nd and so on....deffo no wheel spin in 3rd!
Old Sep 7, 2006 | 03:11 PM
user 7082039239
It's the technique which has been used by Ford mechanics for the last 20 years.
Old Sep 7, 2006 | 04:34 PM
addiction's Avatar
addiction
Originally Posted by PeterRST
"Official" method.
spot on that is you wont make full boost in 1st and 2nd gear,4th is the best way to check
Old Sep 8, 2006 | 03:57 PM
Oranoco's Avatar
Oranoco
You're just not trying hard enough
Old Sep 8, 2006 | 04:10 PM
SafeChav's Avatar
SafeChav
Well mine boosts so hard i had to fit a DV so ner ner ner
Old Sep 8, 2006 | 04:11 PM
scottbrown's Avatar
scottbrown
i was also told that as you usually hold 4th gear longer it lets you see if the boost creeps up slightly higher in 4th. This is why peeps with standard ecus often hit the boost cut in 4th but not in any other gear
Old Sep 10, 2006 | 11:21 AM
rstel1's Avatar
rstel1
nice post safechav they got a bit carried away there mate didnt they lol
Old Sep 11, 2006 | 08:51 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
i had a biscuit boost the other day!
twas quite yummy,
Old Sep 11, 2006 | 09:22 PM
SafeChav's Avatar
SafeChav
twas quite yummy,
And before u go, siggy police please
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
