Few probs with my s2,can anyone help please?
Just brought another s2 of a mate,but has a problem,it dont seem to boost properly and makes a strange whineing noise not the usaul loud sucking noise?and seems as if theres some sort of faint missfire there?Also now and then it will thro out big puffs of white smoke,did it just sitting there ticking over and also as i stoped at a junction?
Any help asap with be greatfull cheers
Thanks for replys,it hard cos i think its either the turbo or head gaskit,theres no white stuff under cap and have not checked water level as it has a alloy header tank.
How can i find out for sure if its the head gaskit?
cheers
cheers
The best way to check the head gasket is to get tester kit that checks the gasses coming out of the header tank. The liquid in the tester turns a different colour if exhaust gases are present.
Dave
Dave
cheers dave,i was ringin around to try and buy that kit but no1 round my way seems to sell them but i did get told some bloke who runs a garage will do it for free so il pop down there tomo.
Not sure if its connected to the problem but when the rs is low on petrol it has been cuttin out at junctions,and i tapd the bottom of the tank and something is lose and rattles on the bottom of the tank inside?anyone think this may be the problem?
Maybe the fuel pump is causing that noise. Had that on mine recently. You should always make sure to have at least 10 litres in your tank. They have a tendency of running dry.
But maybe yours is knackered anyways. Usually the pump should run for a second when you turn the key to ignition. What does it sound like then?
CabrioTurbo
Aug 1, 2015 11:04 AM
