Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
What camshaft for RS2000 16v
Old Sep 2, 2006 | 08:21 AM
MK5RS2000's Avatar
MK5RS2000
Default What camshaft for RS2000 16v
What model of camshaft for RS2000 sport-road and circuit with the stock pistons
thank you
Old Sep 2, 2006 | 09:22 AM
Wardy257's Avatar
Wardy257
There are not many available, and to get the most out of them you need an aftermarket ECU. I would fit an aftermarket ECU and get your car mapped first.
Old Sep 3, 2006 | 11:44 PM
rs_daz's Avatar
rs_daz
You can get a kent cam kit priced at around £176 at a bhp gain of up to 18.
A Piper fast road cam kit priced around £204 at a gain of 10bhp
A piper ultimate road cam kit same price as above at a gain of up to 15bhp
Thats from www.motorsportworld.co.uk
Old Sep 4, 2006 | 08:24 PM
MK5RS2000's Avatar
MK5RS2000
I have a superships, a free exhaust, indution, and maybe soon big injectors.
What model choose, fast road, ultimate road or kent cam.
Kent Cam is less expensive than Piper Cam, Is it same quality?
Old Sep 4, 2006 | 11:01 PM
rs_daz's Avatar
rs_daz
ive heard Piper are the better ones to choose
Heard Kent wear fast
Old Sep 5, 2006 | 05:05 PM
MK5RS2000's Avatar
MK5RS2000
OK, thank you
Witk my setting I do monting fast road, or I can choose the ultimate road? and if I find a mainfoild (bigger).
Old Sep 5, 2006 | 07:25 PM
Wardy257's Avatar
Wardy257
Change the cam, change the airflow through the head. Unless you adjust your ignition and fuelling it is not really worth the effort.
Old Sep 6, 2006 | 12:07 AM
rs_daz's Avatar
rs_daz
There was a guy selling a different manifold like the one in the picture on your other thread think he wanted £400 for it..
Ive taken the APS(EGR) off mine and ported and polished it. Works pretty well now..
Old Sep 16, 2006 | 07:29 PM
paulgrs2's Avatar
paulgrs2
airflow on a standard head is excellent at 120.5 cfm at .375 valve lift so extensive head work ain`t really required, maybe a little tart up with a polish and removal of the slight edge in the throat may give ya a few cfm more.
Cams a bit of a norze with this engine. Standard cams give you more lift than 25% of the valve diametre so no benefit is really gonna be made there as regards increasing valve lift.
The kent cam on offer and the piper road cam only give approx 20 degrees more duration give or take a few degrees.
I am going for the piper ultimate road cam on my rebuild, based purely on the fact the inlet duration duration is a good increase. Hopefully this ain`t going to have no or little effect on the idle speed.
Old Nov 12, 2006 | 05:51 PM
MK5RS2000's Avatar
MK5RS2000
OK, thank you
sorry for the late to answer.
Ian1964
12
Jan 26, 2021 11:57 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
Nov 1, 2015 06:53 PM
liamT74
Sep 23, 2015 10:24 PM
Marino
Sep 12, 2015 11:10 AM
