What is this fuse/relay for????????????????????
Aug 19, 2004 | 10:22 PM
What is the single yellow relay that is tucked up in the passenger footwell, It is clipped to something right up under the dash?
It sit alone right behind the glove box?
Basically when i turn the car over and it fires, this relay carries on clicking for a few seconds????????
The car cut out a few times tonight and thought this might be the problem
Aug 19, 2004 | 10:34 PM
Isnt that for the fuel pump? Im sure theres a few relays behind there & the one with the fuse on it is the fuel pump relay. I stand to be corrected.
Aug 19, 2004 | 10:35 PM
No mate, i know it is not the pump one as that has a fuse and a relay in line
This one is on its own on the side of the footwell
Aug 19, 2004 | 10:38 PM
Start the car up & switch everything on & then take the relay out of its holder & see what happens.
Aug 19, 2004 | 10:39 PM
Aug 19, 2004 | 10:40 PM
Aug 19, 2004 | 10:43 PM
Something to do with the abs pump?
Aug 19, 2004 | 10:44 PM
Dont forget Tiff, EVERYTHING on. Even the fogs cos the wiring can be baffleing and used wierdly at times
Aug 19, 2004 | 10:47 PM
Lee
Even the rear wiper will be on mate
Aug 19, 2004 | 10:49 PM
IainRS1700T
Sep 25, 2015 06:44 AM
steve.rst
Mar 8, 2014 06:31 PM
ShiftyOldScoob
Nov 18, 2010 09:24 PM
fordsportjay
Oct 26, 2010 05:40 PM
Big Will_
Oct 1, 2010 10:16 PM
