another feckin PROBLEM!!!!!!
Old Aug 19, 2004 | 04:04 PM
Paul_RS's Avatar
Paul_RS
Default another feckin PROBLEM!!!!!!
ok just put my turbo back on and now the car wont start (escort rs turbo) It did start the first time i tried it, but it dies after a minute. Now it turns over but wont start. Their is a spark and the fuel pump is working. I took one of the plugs out and it was dry after a few failed starts. Does this mean there is no fuel getting to the engine? The fuel distributor is clicking when i turn the ignition on.
Please help i need to get the car sorted for work tomorrow!
Old Aug 19, 2004 | 04:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
Air leak.
Old Aug 19, 2004 | 04:10 PM
Paul_RS's Avatar
Paul_RS
in the boost hoses? i thought that could be a problem, but why di the car start the first time, idle then die?
Old Aug 19, 2004 | 04:37 PM
Paul_RS's Avatar
Paul_RS
Old Aug 19, 2004 | 04:50 PM
Paul J's Avatar
Paul J
Check everything is reconnected, eg crossover pipe air sensor.
Old Aug 19, 2004 | 05:00 PM
Paul_RS's Avatar
Paul_RS
I just had a look over it and i cant see anything not connected up. I also checked/tightened all the boost hoses too.
I am beginning to hate this car!
Old Aug 19, 2004 | 05:14 PM
Stoo's Avatar
Stoo
Is the lead at the coil on properly?
Old Aug 19, 2004 | 05:15 PM
Stoo's Avatar
Stoo
Sorry just noticed you said your getting a spark
Old Aug 19, 2004 | 05:17 PM
Spax's Avatar
Spax
had this prob on mine after i split a hose down the motorway, it let it idle then died, then wouldn't start, found the hold fixed it and started straight away
Old Aug 19, 2004 | 05:25 PM
Paul_RS's Avatar
Paul_RS
ahh i'm gonna take all the hoses off and put them on again i am i right in thinking that even the smallest hole will cause problems? Also is there anywhere other than the hoses an air leak could happen? intercooler obviously, but anywhere else?
Old Aug 19, 2004 | 06:42 PM
Spax's Avatar
Spax
yer a slight leak in a boost hose will make it die, just check them all for small leaks, I know it's hard to find em but I did in the end
Old Aug 19, 2004 | 06:50 PM
Paul_RS's Avatar
Paul_RS
double checked all the hoses and stil no joy
Old Aug 19, 2004 | 06:52 PM
Spax's Avatar
Spax
Deffo a hose by the sounds of it,checked the boost hoses? all over? think those are the main ones,for some reason it won't run with a hole in a hose?
Old Aug 19, 2004 | 07:18 PM
220TC's Avatar
220TC
are you sure your fuel pump is working ? I had a problem like this where the fuel pump would prime when I turned the ignition on but when you cranked the car it would stop working. Try putting a new pump relay in or crank the car and get someone to loosen one of the injector pipes on the metering head, you'll definately know if your getting fuel that way.
Duncan
Old Aug 19, 2004 | 07:36 PM
Paul_RS's Avatar
Paul_RS
the pump is deffo working, it primes ok and you can hear it running when cranking. i took one of the fuel pipes off the metering head and when i cranked it nothing came out, there is pressure because i got some petrol in the face when i took off the union from the fuel filter to the metering head! So is the problem with the metering head?
Old Aug 19, 2004 | 07:47 PM
The problem you are having is that the metering flap is not being displaced by the airflow going into the engine.
Have someone depress the metering flap slightly (Less than 1mm) whilst you crank her with WOT and see if she fires... If she does you are either leaking air into the engine or the base settings are no longer suitable for your engine and she needs setting up to make her run.
Old Aug 19, 2004 | 07:49 PM
220TC's Avatar
220TC
I think when the pump primes, thats what creates the pressure. Could be the metering head itself could also be the fuel ecu or the electro magnetic pressure actuator I suppose, best to get a Bosch specialist look at it I think
cheers, Duncan
Old Aug 19, 2004 | 07:50 PM
Paul_RS's Avatar
Paul_RS
Cheers STU i'll try that! oh sorry to sound stupid but what does WOT mean?
Old Aug 19, 2004 | 07:51 PM
James Raby's Avatar
James Raby
Makes me laugh everyone saying boost hoses
One thing I will ask, why you take the turbo off in the first place??
Old Aug 19, 2004 | 08:01 PM
Paul_RS's Avatar
Paul_RS
i broke one of the studs that holds the exhaust downpipe onto the turbo
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
