cheapest -31 ? do they come preset? wot boost should it run?
Old Aug 19, 2006 | 08:33 AM
woodz77's Avatar
woodz77
Default cheapest -31 ? do they come preset? wot boost should it run?
my mates actuator isnt holding anymore and he has decided to get a -31. the car is only running standard but he is thinking of chipping it so this seems the best idea.
but for the moment he only wants to run standard. his boost gauge is in bar. its a 90 spec escort turbo withta hearts and diamond ecu . what bar should he be running and does the -31 come preset to a amount . or is it a case of playing with it to get it right .
stupid question but is it winding it in , which increases boost ??
wheres the cheapset place to get a -31??
Old Aug 19, 2006 | 09:06 AM
Jim Galbally's Avatar
Jim Galbally
with the correct preset on it and NO bleed valve/amal it will hit about 7/8psi boost
you acheive the extra boost with a bleed valve/amal valve
Old Aug 19, 2006 | 09:08 AM
ballin's Avatar
ballin
they dont come preset no, max he can run on that ecu is 10psi (0.68 bar!)
i would just wind it as high as it will go before hitting the boost limiter then just turn it back a tad for hot days.
shorten the rod to increase boost
Old Aug 19, 2006 | 09:55 AM
woodz77's Avatar
woodz77
Old Aug 19, 2006 | 10:05 AM
Jim Galbally
winding the fucker right in will shorten the life of the spring somewhat tho
Old Aug 19, 2006 | 10:12 AM
Taz's Avatar
Taz
Visitor from the Darkside
I have a Garrett -31 sale that was only on my car for a few days and is basically brand new if your frind wants one.
£50 delivered.
Graham
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
