Strange electric headlight problem - any ideas?
Old Aug 15, 2006 | 12:30 AM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Default Strange electric headlight problem - any ideas?
On my Mk3 Fiesta both headlights work fine on dipped beam, but only the left hand side worked when switching to full beam
This is strange as they both use the same bulbs - ie dipped and full beam elements within same bulb.
I have swapped the bulbs over and still no change.
Also played about with the wiring and no change either - any ideas? This problem started totally out of the blue
Old Aug 15, 2006 | 12:43 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
probably the stalk, easily replaced and worth trying
Old Aug 15, 2006 | 06:06 AM
whitneyd's Avatar
whitneyd
It's a bad ground. I've seen this a lot on older escorts and fiestas.
Old Aug 15, 2006 | 07:35 AM
AlexF's Avatar
AlexF
diagonsis is easy...
Check for power (12v) both sides.... so check fuses as well.
Check grounds.
That should allow you to find the problem, be it a ground or a stalk!
Alex
Old Aug 15, 2006 | 11:19 AM
AGAR-COSWORTH
Redumbdancy
Check grounds.
Alex
Where are the grounds i should be testing? The ones connected to the inside of the wing?
What the common problem with the stalks exactly - the cars a mk3.5 to be specific (and i have heard somewhere thier stalks are different from mk3's)
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Palethorpe01
15
Aug 18, 2015 06:09 AM
xr_craig
Aug 7, 2015 06:00 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
Bezzy41
Aug 3, 2015 10:31 AM
