fitting a coil pack
Old Aug 14, 2006 | 07:58 PM
mk3cable's Avatar
mk3cable
Default fitting a coil pack
Can you fit a coil pack without using an ecu?
Old Aug 14, 2006 | 07:59 PM
AlexF's Avatar
AlexF
not really
Old Aug 14, 2006 | 08:00 PM
mk3cable's Avatar
mk3cable
forgot to mention it's to fit on a mk3 escort and dont want to change the loom.
Old Aug 14, 2006 | 08:03 PM
costina's Avatar
costina
Live long and prosper!!
Depends what its for luminition do a kit for a pinto called i-fire still uses the dizzy for the advance curve but also uses a coil pack.
for ohv and pinto's Ł300
Old Aug 14, 2006 | 08:06 PM
mk3cable's Avatar
mk3cable
i have done a zetec conversion. Im currently using an 8 valve head but want to use the 16 valve.Im using carb so i dont need all the injection shit.
cheers
Old Aug 14, 2006 | 08:08 PM
Ginge !'s Avatar
Ginge !
just finding my feet
erm,,,,,,,,,,,,,,, just think about it for a while
you dont wanna change the loom but you wanna fit the coil pack,,,,,,,,,, if you dont want the car to spark then yes otherwise its loom swop me freind
it aint gonna work or everyone else would be doing it
Old Aug 14, 2006 | 08:10 PM
Ginge !'s Avatar
Ginge !
you MAY be able to get awy with a 1300hcs engine as i think thats carb and coilpack
i could be wrong though as its been years ssince i opned the bonnet on one of them
Old Aug 14, 2006 | 08:53 PM
the original's Avatar
the original
Default Re: fitting a coil pack
I used a screwdriver
Old Aug 14, 2006 | 09:53 PM
James's Avatar
James
As he said, mk3 fiestas/mk5 escorts carb'd models are a good source of parts.
You'll need the coil pack, module and a few sensers, a crank position senser-1.8cvh parts maybe?- and a few wiring mods and you'll be sorted.
Someone said above, if it was possible everyone would be doing it, well, they are in the kit-car zetec conversion world.
borboyous
Aug 22, 2015 11:17 AM
marky_g
Aug 15, 2015 10:43 AM
155lee
Aug 14, 2015 11:21 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ricky
Jul 31, 2015 10:30 PM
