air charge gauge
Old Aug 8, 2006 | 07:17 PM
swerv's Avatar
swerv
Default air charge gauge
bought one of these last week...the digital type...and cant get it to work!!
it works with the ignition on but as soon as you turn the key the display goes blank but still lit?
any ideas?
Old Aug 8, 2006 | 07:19 PM
dave_y's Avatar
dave_y
fitted mine at the weekend and it works fine
did you get it from R&B Motorsport?
Old Aug 8, 2006 | 07:38 PM
swerv's Avatar
swerv
no, i got it from ebay.
i swear thats the last bit of junk i buy off ebay
it was a trader though
he reckons the wiring is dodgy on the car
Old Aug 8, 2006 | 07:40 PM
SafeChav's Avatar
SafeChav
You must have it wired wrong if it works with the ignition off....
Old Aug 8, 2006 | 08:00 PM
swerv's Avatar
swerv
yes thats what we thought, we have gone over and over it and cant find anything.*
would a change in voltage cause it?
*disclaimer - i did not wire it
Old Aug 8, 2006 | 08:19 PM
James Raby's Avatar
James Raby
Silly boy, Mike charges 40 i think for an ACT gauge
Put a claim in on ebay forms, 9 times out of 10 money back
Old Aug 8, 2006 | 08:37 PM
dave_y's Avatar
dave_y
has it been wired into a live feed instead of an igniton feed?
think i did a similar thing when i wired in my gauges for the first time when i think about it.
Old Aug 9, 2006 | 01:54 PM
swerv's Avatar
swerv
i must put a firewall on ebay.....must not use....
i do it everytime and never learn
may buy one off mike soon as i need one...
cheers guys
Old Aug 9, 2006 | 02:19 PM
LEE-RS's Avatar
LEE-RS
Custom
cant see it being the gauge mate if it works when the ignitions on but not when you start it sounds like its not wired up right my brother bought one off ebay his works fine
Old Aug 9, 2006 | 06:40 PM
iamrab's Avatar
iamrab
sure if u wanna know what its just turn the car to the reds again ....... ....;p
Old Aug 9, 2006 | 11:10 PM
gee1599's Avatar
gee1599
i got one of them worked fine untill you start the engine so i even gave it its own power supply from a 12v batt and still done it send it back and get one from r&b motorsport fitted it and worked first time
all i can say is more e bay s**t
Old Aug 10, 2006 | 07:19 PM
swerv's Avatar
swerv
ah so not the only one who have had probs
its been really stumping us as we wired direct as well
Old Aug 12, 2006 | 01:46 PM
radiant red's Avatar
radiant red
was it from aautoelectronics?
Old Aug 12, 2006 | 02:27 PM
swerv's Avatar
swerv
evolution_r_auto
had no replys from them at all after i told them i wired direct!!
Old Aug 12, 2006 | 05:15 PM
SafeChav's Avatar
SafeChav
File a dispute for an item significantly not as described in paypal and get your money back
Old Aug 13, 2006 | 06:35 AM
Rallyesport's Avatar
Rallyesport
You need to put the sensor wire as far away from the HT leads as possible. It's the interference that makes it go blank.
Old Aug 13, 2006 | 12:53 PM
SafeChav's Avatar
SafeChav
you'r saying HT interference is making the unit power down.....
Old Aug 13, 2006 | 07:38 PM
swerv's Avatar
swerv
this is the thing the unit is not powering down the backlight is still on , its the digital display that goes...
the sensor is mounted very closs to the throttle body so not near the HT leads
Old Aug 14, 2006 | 12:20 AM
SafeChav's Avatar
SafeChav
How many wires has the unit got, and where does it say to connect them to and what is each wires label/function?
Old Aug 14, 2006 | 07:07 AM
swerv's Avatar
swerv
unit only has 2 wires, one earth and one positive.
wired the positive to both ignition and perm live just see what happens.
had a PDF file with all the instructions so cant really go wrong with the colour of the wires.
going to re-wire before its sent back just to double check.
Old Aug 14, 2006 | 09:53 AM
SafeChav's Avatar
SafeChav
Lol, 2 wires
I don't think you are wiring it wrong then
So, you connect it up, and you say it works until you switch the ignition on?
Old Aug 14, 2006 | 10:13 AM
swerv's Avatar
swerv
it works with the ignition on, when you run the engine the display goes.
i think it may have something to do with the voltage going to it?
Old Aug 14, 2006 | 11:23 AM
SafeChav's Avatar
SafeChav
Ok
so, with the car running, what happens if you connect it across the battery directly?
Old Aug 14, 2006 | 12:03 PM
Rallyesport
It dosen't power down all togheter, the display goes blank but the light is still on. This is caused by HT interference, so you need the either place the sensor wire as far away from the HT leads as possible or shield it. I have the same gauge and had the same problem, when I routed the sensor wire differently, it worked without going blank.
Old Aug 14, 2006 | 12:06 PM
Rallyesport
sensor _wire_
Old Aug 14, 2006 | 01:08 PM
SafeChav's Avatar
SafeChav
Well if that fixed your problem then fairplay, but the words "cheap" and "crap" spring to mind
No offence like
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
