My thermite experiment
Guest
Posts: n/a
Thought I'd have a bash at making some thermite for a laugh, 1st attempt was shit, proper gutted that it didnt work
vids below;
Attempt 1 = bugger
Attempt 2 = more mixture, getting there
Attempt 3 = holy shit, light the blue touch paper and stand well back
The amount used in the last attempt was only 15g
imagine what 100g, 500g or 1kg would go up like
Bit gutted I didnt get to melt anything, although the intercooler in the second attempt got hole melted and filled in the same process
More attempts needed with bigger mixture, and a longer arm
PS, cheers to Paddy for showing me how to put links in proper
vids below;Attempt 1 = bugger
Originally Posted by Matt J
Not quite
And be careful what you type, I'll have the front door kicked in and be shipped to gauntanamo bay before you can say bin laden
Not quite
Those cells are bigger than most office cubicles too and you get let out for an hour of exercise!
Whats worse is any muppet can buy the stuff over the counter
Guest
Posts: n/a
Fuck me! this is what 500g goes up like
http://www.amazingrust.com/Experimen...cs-videos.html
Scroll down the list till you find it
If you get the mix right you could drop it on the bonnet of a car and it will burn right down through the bonnett, head, block, sump and into the tarmac. Fookin leathel shite altogether !
Mate at uni did it on a scrap car once too, it really does work that well, scarey that it can be so easily made by any old idiot at home (no offence to topic starter
Guest
Posts: n/a
Only thing I dont understand is the flower pot thing, I put one over the top of 15g to try and stop the sparks spreading, and it blew up.
Yet they put about 1kg
in that plant pot on the 205 and it took it no probs
can you get different quality/material flower pots? I thought they were all the same!
in that plant pot on the 205 and it took it no probs Guest
Posts: n/a
Originally Posted by SECS
Matt,
You are crazy doing that inside as the reactions are unstoppable
Still, looks like a load off fun.
Thats why it was done over a knackered sink
