turbos
a cosy turbo will bolt onto your manifold as long as its a escort manifold for a t3
they are virtually the same turbo bar the ex housing where you would need to modify a cosy down pipe to your exhaust
these are less restrictive that a erst hosuing an a lot of people use them
or if you want to use your erst housing the cosy t3 will bolt straight in
just take the ex housing off the cosy turbo and put it into the erst housing
i done this on my turbo
this sounds good! my exhaust is broke at the top where it bolts to the waste gate so it doesn't matter that I need to modify it!
so do I need turbo and wastegate?? where can I get a cossie downpipe??
cheers
cheers
so do I need this downpipe??
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
is the bracket which is used to bolt on missing or does it bolt on different to the rsts?
do I need a wastegate as well as turbo?
thanks
thanks
thanks
thanks
what you need is a complete cosy turbo
and a cosy downpipe not the one in the link
ill get a pick of one tomorrow for you
im about to chuck a std cosy exhaust away but its a smaller diameter to a stainlees item
what diameters that then? a standard cossie diameter might be the same size as the exhaust on my car now! mines 63mm
if its the same size I will buy it off you if you are willing to sell?
its milod steel
and im sure its a smaller diameter than a rst stainless
ill measure it later and let you know
you can have it for sod all if you can use it but u will have to collect
JK12
33
Apr 26, 2021 12:09 PM
