4x4 driveshafts
Old Aug 3, 2006 | 06:47 AM
filthyrichie's Avatar
filthyrichie
Default 4x4 driveshafts
daft question just had 2 recooned by amk and they have given back new units ....1 is longer than tother does the longer 1 go in the drivers side front???
Old Aug 3, 2006 | 06:53 AM
dojj's Avatar
dojj
Resident Wrestling Legend
fronts or rears?
fronts shold be eaqual lengths, the rears are sometimes longer/shroter
Old Aug 3, 2006 | 06:58 AM
filthyrichie
fronts they look different to me only by about an inch tho, but it cud be the gaitors holding it out
Old Aug 3, 2006 | 07:09 AM
Mr RS500's Avatar
Mr RS500
Front shafts are the same mate ,
Old Aug 3, 2006 | 07:10 AM
filthyrichie
cheers guys, do they need the circlip back on in the diff casing or can you leave them out ,misplaced ,mine
Old Aug 3, 2006 | 07:14 AM
Mr RS500's Avatar
Mr RS500
Most rally men leave the clip off as it lets the shaft move more , Allows more travel and stops the shaft breaking
Paul
Old Aug 3, 2006 | 07:15 AM
filthyrichie
thanks alot mate will go and chuck them in now
have a good day
Old Aug 3, 2006 | 07:25 AM
Mr RS500's Avatar
Mr RS500
Dont forget ,,lots of grease on the splinds
Old Aug 3, 2006 | 08:50 AM
xr4x4rs's Avatar
xr4x4rs
the xr4x4 ones are and inch longer than cosys
they both should be the same size in length
better off with the longer ones anyhow
Old Aug 3, 2006 | 10:15 AM
dojj's Avatar
dojj
but the longer ones sometimes don't fit
we've had this problem posted about twice in the last fw weeks haven't we? still don't know what they did about getting them sorted
Old Aug 3, 2006 | 10:17 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
used the standard ones?
Old Aug 3, 2006 | 10:20 AM
JTECH James
Passion for Fords!
i couldnt use the xr shafts with my koni -25mm suspension so had to use standard shafts, now with coilovers i can run a bit lower so the xr shafts fit fine with no probs.
If you have one long shaft and one short one, the long one should go on the o/s as thats the one that causes most problems ,
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
mondeomark
Sep 28, 2015 06:28 AM
