setting boost on -31 with preload only
Old Aug 2, 2006 | 11:56 AM
Neil's Avatar
Neil
Default setting boost on -31 with preload only
as above and when u start getting boost, currently start around 2600 rpm full boost around 3100 rpm
Old Aug 2, 2006 | 12:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Want to retype that so it makes some sort of sense? Theres no actual question in there...
Old Aug 2, 2006 | 12:20 PM
Neil's Avatar
Neil
ok
how do u set the boost on a T3 with a -31 actuator with preload only and when do u get full boost in your cars
Old Aug 2, 2006 | 12:45 PM
flashpoint's Avatar
flashpoint
At what point you get full boost depends on a lot of things, the size of the turbo being the largest factors.
Install the -31, connect up the control pipe to the -31 adjust the preload to achieve the desired boost and away you go...
i would start off with about 1mm preload, and see what boost you get.
I think the max preload you are supposed to run on a -31 is 3mm if memory serves me well
I get full boost about 3400 rpm under hard load
Steve
Old Aug 2, 2006 | 12:53 PM
Neil's Avatar
Neil
at moment got 1 full hole of preload on actuatoer which gives me 16psi
Old Aug 2, 2006 | 01:02 PM
flashpoint's Avatar
flashpoint
That about 4mm preload, what sort of boost are you after
Steve
Old Aug 2, 2006 | 04:55 PM
Neil's Avatar
Neil
will be around 23psi eventually once larger injectors fitted and 3 bar map
Old Aug 2, 2006 | 09:44 PM
flashpoint's Avatar
flashpoint
you will end up having to use some kind of bleed system to achieve that kind of boost
as that is way more than the -31 can cope with on preload alone
i would set the preload to give you 12 psi boost and then use a 50/50 bleed to achieve 23 psi boost.
good luck
Steve
Old Aug 3, 2006 | 10:56 AM
Neil's Avatar
Neil
dont start seeing boost till around 2400rpm, but when on boost it squatts the rears, it like getting a kick up the RS quite strongly and holds 17psi right to rev limter at 6500rpm
Old Aug 3, 2006 | 11:33 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
You could get a old foot pump, lob the end off where it attaches to the tyre & put the hose over the actuator nipple. Then pump the actuator to about 12-14psi & adjust the bar so it slips over the waste gate penny in the closed position ! job done
But anymore than that is stretching the -31 a bit & you might end up with boost creep in the higher gears or snappin the actuator bar or somethin LOL
Also check the boost in like 4th/5th gear when engine load is at it's most !
You could also lengthen the pipe from the compressor to the actuator & give it a little spike in the mid range !
Jb
Old Aug 3, 2006 | 11:57 AM
ballin's Avatar
ballin
jb fletch wicked idea, proper blue peter
Old Aug 3, 2006 | 01:10 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Ballin,
Not what me mum said when i cut her "band new" halford foot pump up ! ! !
Got me own one now !
Jb
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
