Anyone run a S1 gearbox in a S2???
Old Aug 1, 2006 | 08:49 PM
John Laverick's Avatar
John Laverick
Default Anyone run a S1 gearbox in a S2???
Anyone run a S1 gearbox in a S2??? With the standard S2 front anti-roll bar set-up??
I do and the anti-roll bar clashes with the gearbox casing [the end removable bolt on casing]. When the suspension compresses it hits the casing [enough to bend the casing].
Any else noticed this? Or is it just mine??
Old Aug 2, 2006 | 02:02 PM
originalcabbie's Avatar
originalcabbie
Yer I ran a S1 gearbox with the S2 anti roll bar, I never had a problem. I managed to bolt the gearbox onto the cradle by adding the studs from the correct side a few spacers and I was away.
Old Aug 2, 2006 | 02:06 PM
stuart collins's Avatar
stuart collins
im not runnin a front anti rollbar with mine
Old Aug 2, 2006 | 04:32 PM
John Laverick
That doesn't help
Anyone else?
Old Aug 2, 2006 | 05:44 PM
matt p's Avatar
matt p
Im about to put one in mine mate ill let you know
of the results lol
Old Aug 2, 2006 | 06:20 PM
JesseT's Avatar
JesseT
Do you have the antiroll bar installed the correct way around?
Old Aug 2, 2006 | 09:06 PM
John Laverick
matt p - Let me know
JesseT - Yes [I'm pretty sure anyway ]
Old Aug 3, 2006 | 04:36 AM
Wazzzer's Avatar
Wazzzer
I had a S1 box in my RS when I bought it, bolted in exactly the same way with no probs (blew it up a week after I bought the car though )
I've now got a S2 box with S1 diff
Old Aug 3, 2006 | 06:50 AM
originalcabbie
stuart collins
What type of front suspension set up are you running, on a S2 the front anti roll bar is required to hold the front set up in line with the front of the car. Do you have a modified S1 adjustable set up installed?[/quote]
Old Aug 3, 2006 | 07:14 AM
stuart collins
that would be tellin mate, i dont run an anti rollbar at all
Old Aug 3, 2006 | 08:18 AM
originalcabbie
interesting. the only thing you can have is the adjustable S1 or RS 1600i setup or maybe the ones from MEF. I dont know tho but with that much power it must be bloody strong!
Old Aug 3, 2006 | 09:55 AM
SafeChav's Avatar
SafeChav
HEs obviously running the S1 or RS1600i crossmember and tie arms without the rollbar, there is no other way.
As for the gearbox fouling i have no idea whats making contact
Pictures?
Old Aug 3, 2006 | 10:42 AM
originalcabbie
isnt that what i said???
Old Aug 3, 2006 | 07:09 PM
matt p's Avatar
matt p
Will do mate gonna do a step by step do it yourself thing mate
and then post it up
Old Aug 4, 2006 | 08:31 AM
SafeChav's Avatar
SafeChav
Yea was just agreeing with what you were saying
Old Aug 5, 2006 | 07:07 AM
stuart collins
Pictures?
isnt there
Old Aug 5, 2006 | 08:20 AM
SafeChav's Avatar
SafeChav
Pictures?
isnt there
Well by all means correct me if im wrong or is it the worlds best kept secret.....
Old Aug 10, 2006 | 12:17 AM
turbodoctor's Avatar
turbodoctor
the box its if you use the s2 mount n cradle. no slip diff for s1's either.great fun.
Old Aug 10, 2006 | 07:38 AM
JesseT's Avatar
JesseT
Why is this missinformation coming up again and again...
Old Aug 10, 2006 | 07:51 AM
matt p's Avatar
matt p
I was thinking that do they or dont they??
I thought they did
Old Aug 10, 2006 | 03:17 PM
SafeChav's Avatar
SafeChav
Series 1's came with LSD's.
END OF STORY.
Old Aug 10, 2006 | 03:22 PM
matt p's Avatar
matt p
Cheers for clearing that one up mate
Old Aug 10, 2006 | 03:29 PM
SafeChav's Avatar
SafeChav
Old Aug 10, 2006 | 10:23 PM
turbodoctor
sorry. when i baught the box in question the guy assured me it was from a series one. it had the square front mounting point on the front too. maybe it was from an xr3 ripped. it didnt have a bar across when you looked into the hole for the driveshafts. is it true that this is a way to tell?
it also dropped massive burnouts everywhere
Old Aug 10, 2006 | 11:05 PM
dave_y's Avatar
dave_y
no bar through the hole = LSD
interesting fact - The LSDs in Series 1 Boxes are rebuildable unlike the ones in Series 2 boxes. Thats according to Bernie at CTS
Old Aug 11, 2006 | 05:25 AM
JesseT's Avatar
JesseT
The S1 LSD are "better" also because they have the more common six bolt pattern, so the LSD can always be put to whatever other box to make it an "RST-box".
John:
Did you really check that your left and rear on the antiroll-bar are the correct way around? This happens soooo often when people don't realize they are different. The left side takes a different route to better clear the gearbox.
dombanks
Sep 21, 2015 08:38 PM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
gingeRS
Sep 4, 2015 06:29 PM
