Changed stem seals still smoking like mad....
Old Aug 1, 2006 | 07:13 PM
spadey's Avatar
spadey
Default Changed stem seals still smoking like mad....
I have just changed my oil stem valve seals in a hope it would stop my escort cossie replica with a fiesta turbo engine in from smoking... No luck.... Well ive only drove it 2 or 3 miles and its still smoking. Do you think I would need to drive it further to burn the excess oil off? Or like me do you think its still leaking oil??? I did a compression test and it was 150-160 on all cylinders is this correct? Checked the turbo pipes for excess oil and they seem ok>>> Any more ideas? I have a spare head im currently refurbin do you think it would be worth swoppin this completely? Once again thanks for any input....
Old Aug 1, 2006 | 09:58 PM
BRAMMER's Avatar
BRAMMER
What turbo is on it - T2 or T3??
I've had the same problem as this in the past checked everything and it ended up being turbo yet no oil in pipes and no play at all in the turine, shit seals.
Try the breater pot, if its O.E pot then check its breathing properly take all pipes to the sump etc...inspect and try new pot - BAILEY best with a escort rs turbo pot they are bigger than fiesta ones.
piston rings seem okay its producing them figures
Old Aug 2, 2006 | 05:41 AM
spadey's Avatar
spadey
Default re smokin
Hi mate, not sure actually as waiting for the receipt to turn up for the turbo off the guy I got it off... So its probably worth trying another turbo? Really starting to piss me off now... Cheers
Old Aug 4, 2006 | 05:09 PM
RST Ski's Avatar
RST Ski
if the turbo was completely blown before there maybe oil in the exhaust system and its burning it off
Old Aug 4, 2006 | 05:44 PM
spadey's Avatar
spadey
Default re smoke
How long can It take to burn off the excess oil as its def better since the oils seals where changed?? If it was pissing through say could it take a while??? Cheers
Old Aug 4, 2006 | 05:50 PM
RST Ski's Avatar
RST Ski
if it was just the stem seals causing smoking then it shud take minutes to clear
oil in exhaust from blown turbo could take ages, ive replaced exhausts at work because of blown turbo's before as it took ages to burn
could also be the piston rings matey
Old Aug 4, 2006 | 06:07 PM
spadey's Avatar
spadey
Default re smoke
Done a comp test and all 150-160 so dont think its the rings....
Old Aug 7, 2006 | 02:08 PM
BEN FRST's Avatar
BEN FRST
Had this problem with mine would'nt burn the oil out of the turbo so i stripped it all down again, there was no oil in the exhaust so decided to rebuild the car the next day. When i went to it there was a big pool of oil that came out of the turbo overnight, when rebuilt it never smoked again. so try turning the turbo upside down and leaving it overnight to drain out!!
Old Aug 23, 2006 | 11:23 AM
SafeChav's Avatar
SafeChav
There is a common fault on the FRST's that run a T2 - its the oil return pipe. They are very thin and long and are known for bad drainage, Ford i'm led to believe brought out a modified pipe but they are like rocking horse poo to find now.
This may be your problem so bare it in mind
Old Aug 23, 2006 | 01:02 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
more like the oil return is level, as in its at the same angle from the bottom of the turbo as it is in the block. thats why it doesnt drain properly
Old Aug 23, 2006 | 10:19 PM
fezzanut's Avatar
fezzanut
yep thats your problem mate shit design on the return pipe rather than going directly into the sump it takes a detour over the exhaust causing the oil to build up when engine is swithed off flood the turbo and chuck out blue smoke when you start the engine.
Old Sep 19, 2006 | 07:43 PM
daveselwood's Avatar
daveselwood
Default pipe
i have the same problem with my t2 how do i get around it
Old Sep 29, 2006 | 09:33 PM
tanjaz's Avatar
tanjaz
i have this crappy problem too. what can be done to remedy it?
Old Sep 30, 2006 | 07:02 PM
TURBO BOI's Avatar
TURBO BOI
did you use the modded stem seals spadey?
Old Oct 1, 2006 | 07:03 PM
paceo's Avatar
paceo
id like to find this return!
if however they did do one?
rob
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
Brickhouse
Sep 21, 2015 11:00 AM
marky_g
Sep 12, 2015 04:26 PM
