Front CV Boot & Labour – Charge?
Old Jul 24, 2006 | 10:26 AM
Cola's Avatar
Cola
Default Front CV Boot & Labour – Charge?
Hello ya’ll. Getting some work done on the cos (as above) with someone new. Just wanted to check what a rough price would be for this to ensure I don’t get done. Tis on the front of the Escos.
Ta
Old Jul 24, 2006 | 10:48 AM
Billabong's Avatar
Billabong
Can't remember cost, but get them to use a genuine Ford boot as iirc they're thicker/more robust than pattern ones.
Old Jul 24, 2006 | 11:26 AM
Cola's Avatar
Cola
Cheers Luv
Do you know how many hours (ish) the job should take?
Old Jul 24, 2006 | 03:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
less than an hour
less than an hours labour charge
so if they want more than £30 for it ask why
seriously, i've had new cv's fitted for £90 included parts and labour so i can't see it being LOADS of money to do
just make sure they don't break anything else in the procces though, the bottom pinch bolts can be a nightmare if they've rusted into place
Old Jul 24, 2006 | 03:26 PM
Cola's Avatar
Cola
Dojj cheers Dude. I shall use that as a margin
Old Jul 24, 2006 | 05:11 PM
dojj's Avatar
dojj
it's as easy as:
car in the air
wheel off
pop the lower ball joint
remove gaitor
split joint/driveshaft (1 circlip)
remove old grease
fit new grease
fit new boot
pop back together
bottom ball joint back in
wheel on
lower car to the ground
20 minutes with air tools if you are in a hurry
Old Jul 24, 2006 | 06:38 PM
Moose 130's Avatar
Moose 130
most will go by ICME times and charge accordingly.
if anything is siezed then it's more.
I charge £70 all-in for most cars, £90 for Passats/A4's.
Old Jul 24, 2006 | 09:56 PM
James's Avatar
James
personally i'd rather do a passat that anything else, they're well easy when you get the hang of it.
i've got pattern ones on the front of mine and they were £3.50 each. took under a hour to do. although i cheated and undid the arb and the bottom arm away from the sub-frame as i knew the bottom pinch bolt would be a mare so i left it in place.
Old Jul 25, 2006 | 07:49 AM
Cola's Avatar
Cola
Cheers guys, seriously, it's appreciated.
Moose, I'll use 70 quid as my all in price then? BTW, I see Berks.. whereabouts are you?
Old Jul 27, 2006 | 07:31 PM
Moose 130's Avatar
Moose 130
I'm in Wokingham by J10 M4
ICME states 1.1 hours so you work off that.
Cola - seriously , if you're willing to travel, i'll do it cheaper if you're serious.
PM me if you want
Old Jul 27, 2006 | 09:04 PM
Daveyboy's Avatar
Daveyboy
Got it done now mate cheers for offer though
YODI
Aug 30, 2015 01:12 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
C2 MAK
Aug 20, 2015 09:46 PM
Old ford
Jul 31, 2015 06:50 AM
