boost cut
Old Jul 23, 2006 | 10:33 AM
sime73's Avatar
sime73
Default boost cut
can someone tell me if a standard ecu cuts the boost at 8-10 psi as soon as it sees that pressure or does it cut it after a short delay ?
only reason i ask is because mine hit 18 psi last night and i thought i had a standard ecu in mine
Old Jul 23, 2006 | 11:08 AM
Oranoco's Avatar
Oranoco
Standard boost cut iirc on a S2 is 12psi. If you hit 18psi there is eitehr a fault or the ECU has been chipped
Old Jul 23, 2006 | 12:26 PM
Rick's Avatar
Rick
There's a delay. Ant it can be quite big. Ive hit 22psi on a std ecu before. 10 psi is ur cut roughly.
Old Jul 23, 2006 | 12:54 PM
SafeChav's Avatar
SafeChav
Did it cut the boost though when you 18psi??
Old Jul 27, 2006 | 10:12 AM
sime73's Avatar
sime73
nope, but i did lift straight away as its still running in...
Old Jul 27, 2006 | 11:08 AM
SafeChav's Avatar
SafeChav
Somethings up there, if youre getting to round to 18psi without boost cut.
When i turned it up on mine when i first got an RS as soon as it hit 10psi it was back firing from the boost cut.
Old Jul 27, 2006 | 12:25 PM
Stu @ M Developments's Avatar
PassionFords Creator
varies from sensor 2 sensor.
Ecu wants to see the excess boost for 2-3seconds, but how soon your 20year old pressure sensor reports it to teh circuit is another matter.
Old Jul 27, 2006 | 08:37 PM
slimwynn's Avatar
slimwynn
boost cut scarry stuff when u don't no what it is did it to me the uther day and i throught crap what have i broke but all is still well
Old Jul 28, 2006 | 09:22 PM
sime73's Avatar
sime73
Ecu wants to see the excess boost for 2-3seconds, but how soon your 20year old pressure sensor reports it to the circuit is another matter.
yeah i think thats the case, it deffo cuts it after a sec or so at 18-20 psi
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
