Efi
Old Jul 22, 2006 | 02:47 PM
TURBO BOI's Avatar
TURBO BOI
Default Efi
right finished my efi conversion, starts on the key, but when i drive up the road its as flat as anything, i could ride a bike faster, any ideas?
these r the only things i havnt done at the mo, i got the iscv to atmosphere instead of going to the crossover pipe
ive got the original brake servo pipe cut and joined to a take off on the inlet instead of the proper push type efi servo pipe
would these cause this problem^?
if i blank the pipe on the iscv off, it cuts out
if i disconect the iscv it also cuts out out
its not chipped yet, so standard boost with a bleed valve thats wound all the way in
the idle is very low too, but the idle screw is wound out as far as possible
when driving its like the exhaust is blocked, (was fine on mfi)
when i rev it on idle i get chatter so turbo must be spinning up
any help would be grateful chaps
Old Jul 22, 2006 | 03:55 PM
TURBO BOI's Avatar
TURBO BOI
i havnt set up base idle yet, would this make much difference to the lack of power driving? or only the idle?
running OFAC by the way
Old Jul 22, 2006 | 04:25 PM
SafeChav's Avatar
SafeChav
You can't adjust the idle with the screw as far as im aware, the ECU has the idle speed programmed in and therefore controls it.
You sure you've got everything plugged up?
Old Jul 22, 2006 | 05:07 PM
tim10_10's Avatar
tim10_10
If the idle control valve is going to atmosphere do you have the charge carrier vlaneked or are you still using the escort one? Also wouldnt you lose some boost through the idle control valve runing to atmosphere or does it completely shut off when not being used. With regards to idle like safe chav says its predetermined by the ecu you can set base idle with iscv disconnected and adjust the screw you mention should be around 600rpm i think. Is the valve operating properly and not all gummed up?
Old Jul 22, 2006 | 05:17 PM
SafeChav's Avatar
SafeChav
Im pretty sure its ok to run them with a breather filter on the ISCV, i'm sure ive seen cars at shows like this.
Good point though im sure someone will know for definate
Old Jul 22, 2006 | 08:08 PM
TURBO BOI's Avatar
TURBO BOI
im using erst carrier, i did a resistance check on the valve and that was in spec but duno if its gummed up, if i diconnect the iscv to set the idle it cuts out
Old Jul 23, 2006 | 11:30 AM
TURBO BOI's Avatar
TURBO BOI
Right went to play with it just now, is it at all possible that the timing could be out? would this cause this?
when i put the 1.8 sierra pulley on i put it in gear to tighten the pulley up, i know the crank isnt locked untill the gears lock up, so the engine turns abit before it locks, could at this point the belt mayb jumped a tooth? i also found the belt cracked so its about to go at anythime
Old Jul 23, 2006 | 11:33 AM
SafeChav's Avatar
SafeChav
Well first things first get that belt changed before you really cause some damage.
You should really get the bottom pulley on and tighten it as tight as you can by hand, then time it up and tighten the tensioner etc, then tighten the bottom pulley bolt
Old Jul 23, 2006 | 11:39 AM
TURBO BOI's Avatar
TURBO BOI
so with you saying that theres a chance ive could have done what i explained? cos the belts at its weakest and isnt gona holds at much strain?
Old Jul 23, 2006 | 12:36 PM
SafeChav's Avatar
SafeChav
Not necessarily, but like you say when you spin the bottom end over without the belt tightened you could well of jumped a tooth cos the belts loose, so by timing it up first you can then tighten the bottom pulley bolt and it wont jump any teeth or anything
Old Jul 23, 2006 | 12:44 PM
TURBO BOI's Avatar
TURBO BOI
Just checked timing its spot on
SafeChav's Avatar
SafeChav
Well either way get that belt off, don't even risk it for the sake of a Ł10 belt!!!!!!
Old Jul 23, 2006 | 12:49 PM
TURBO BOI's Avatar
TURBO BOI
yeh defo
what i did notice tho was that the crank pulley had very slight play in it even when tight, could this affect the cps signal?
Old Jul 23, 2006 | 12:52 PM
SafeChav's Avatar
SafeChav
Are you talking the actual cam belt pulley or the sierra pulley?
To be honest though nothing should be loose really
Old Jul 23, 2006 | 12:57 PM
TURBO BOI's Avatar
TURBO BOI
ive got sierra pulley, i can only explain the movement as the same sort of play you get in a turbo shaft, very little, but im wondering if this is enough to affect the cps signal causing it to be really flat?
Old Jul 23, 2006 | 01:12 PM
SafeChav's Avatar
SafeChav
Well, being loose isn't good..........it should really not move at all because it gets sandwiched between the belt pulley and the bolt.
But movement is more then likely going to affect the signal.
When you change the belt, clean up the back of the pulley etc, if theres bit of dirt etc stuck to it making the contact faces uneven this won't help, use some emery paper or whatever.....if you get me?
Old Jul 23, 2006 | 01:34 PM
TURBO BOI's Avatar
TURBO BOI
yep i no what u mean, il put new belt on and clean up the pulley surface see if that makes a difference
Old Jul 23, 2006 | 03:14 PM
TURBO BOI's Avatar
TURBO BOI
i found this on rs bible
"The E-DIS 4 module uses the SAW signal to control the DIS coil. If the EEC-IV module develops a fault, a Limited Operation Strategy (LOS) comes into effect allowing the driver to continue the journey but with restricted power and economy"
this is like what mine feels like
Old Jul 23, 2006 | 03:31 PM
TURBO BOI's Avatar
TURBO BOI
think i found it, dodgy connection to last reminal on the e- dis unit
Old Jul 23, 2006 | 08:36 PM
SafeChav's Avatar
SafeChav
Theres usually some tell tails signs if theres a fault.
Have you tried giving it a good thrashing now?
Old Jul 23, 2006 | 10:06 PM
TURBO BOI's Avatar
TURBO BOI
ill slap a new timing belt on 2mura first as it looks like it could go ping at anytime and fix that wire on the e-dis unit, then fingers crossed
Old Jul 24, 2006 | 09:05 AM
SafeChav's Avatar
SafeChav
Ah TRUE
Old Jul 24, 2006 | 02:37 PM
TURBO BOI's Avatar
TURBO BOI
new belts on, fixed the e-dis wire, went down the road SORTED, efi conversion done
SafeChav's Avatar
SafeChav
Old Jul 24, 2006 | 02:39 PM
TURBO BOI's Avatar
TURBO BOI
i creamed my pants when i heard the chatter
Old Jul 24, 2006 | 02:44 PM
SafeChav's Avatar
SafeChav
TOO MUCH INFO
Old Jul 24, 2006 | 02:57 PM
TURBO BOI's Avatar
TURBO BOI
Get ur finger out mr safe chav and join the club
Old Jul 24, 2006 | 03:11 PM
SafeChav's Avatar
SafeChav
Fuck me ur havin a laugh just been packing a head up for eBay and im sweating like a paedophile in a playground, let alone working on the car
Ive got a Series 1 to fix for someone this week anyway, and i get to use it while hes away on work
Old Jul 24, 2006 | 04:15 PM
Rab's Avatar
Rab
Fucking superstar........
Glad it's all running mate. Get it chipped and set up. It'll fly.
Old Jul 24, 2006 | 04:22 PM
SafeChav's Avatar
SafeChav
Do you offer a satisfaction guarantee with the quote "it will fly"
Old Jul 24, 2006 | 04:26 PM
Rab's Avatar
Rab
I'll leave the 'satisfying' of the boys to you mate
Old Jul 24, 2006 | 05:00 PM
SafeChav's Avatar
SafeChav
well..............
what can i possibly come back to that with.........
ive clearly been taught by the best MASTER
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
