hello peeps im just wondering if anybody can shed some light on why my s2 erst really takes a while to start from cold,turns over ok.but once its warmed up a bit it starts on half a turn,ive already checked the cold start valve(unplugged it and tried starting it) and that dont seem to make any difference,so whats the next step???
yeah its fine wen its running and has been warmed up ok but for example if i leave it overnight and come out to start it up for work it takes a good 5 to 6 cranks to get it to start,but like i say when its warmed up half a turn and its fine.idles fine also just the initial start up thats the problem
exactly the same with the cold start valve either plugged in or unplugged
Mine probably takes about 4-5 seconds and misses the first couple of fires, starts first click everytime after that, until its been left for a day or more
mines exactly the same...takes about 5-6 seconds to start but got to rev it otherwise the revs drop and it cuts out. but then it'll be fine for the rest of the day
