boost on light blues....
Old Jul 15, 2006 | 05:49 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default boost on light blues....
now then i want 2 know wot the max amount ov boost that can b ran on light blues ive got a t34.63....p.s just answer the ? asked please (dont want 2 know about other injectors) cheers.
Old Jul 15, 2006 | 06:09 AM
bud-weis's Avatar
bud-weis
Football Cwazy
around 2 bar max dependant on fuel pressure i'd guess
Old Jul 15, 2006 | 08:04 AM
Redkop's Avatar
Redkop
I've got light blues on my car and running 27.9psi boost peaking at about 31psi.
Old Jul 15, 2006 | 09:10 AM
Dunccoss's Avatar
Dunccoss
mine ran 33 psi on the same turbo as you at 3500rpm and dropped off to 26 psi at 7000 rpm
Old Jul 15, 2006 | 09:22 AM
Redkop's Avatar
Redkop
My boost gauge is only 2bar so 27.9psi is a good setting for me
Old Jul 15, 2006 | 10:52 AM
pete mcrash
nice one guy people its a good step up from greens then...sound thanks 4 ya time
Old Jul 15, 2006 | 10:59 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Will fit my 400s when i have run the engine in
Not worried about getting the max out of them, just want abit more than my greens.
28 peak will do for me.
Steve.
Old Jul 15, 2006 | 11:03 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
35 psi spike and a held 30-31psi.
Mark Sheads escort cossie used to do this.
Old Jul 15, 2006 | 11:05 AM
stuart collins's Avatar
stuart collins
2 bar on a 1600 turbo and they are nearly maxed
Old Jul 15, 2006 | 11:07 AM
Alpina's Avatar
Alpina
I run 2 bar on my light blues with a Harvey Gibbs T34 with 48 housing
Old Jul 16, 2006 | 07:23 PM
pete mcrash
the car should b mint then when the engines done it ran just under 360bhp b4 (standard engine) now low comp blue print engine with a few more psi should b good 4 nearly 400bhp im guessing.... fingers xxxx
The Enigma
Sep 12, 2015 10:12 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
fuzzy
Sep 4, 2015 10:11 PM
