cosworths most common faults
Old Jul 15, 2006 | 04:15 AM
rsvan's Avatar
rsvan
Default cosworths most common faults
looking for the most common faults that youve come across
Old Jul 15, 2006 | 04:31 AM
Cam's Avatar
Cam
the owners
Old Jul 15, 2006 | 06:10 AM
bud-weis's Avatar
bud-weis
Football Cwazy
missfires never on mine though
Old Jul 15, 2006 | 06:29 AM
Eagle's Avatar
Eagle
Super Moderator
the fact you need to visit the petrol station to often ...
Old Jul 15, 2006 | 06:35 AM
Paddy's Avatar
Paddy
Legend
Originally Posted by Eagle
the fact you need to visit the petrol station too often ...
To stock up on pies?
Old Jul 15, 2006 | 06:46 AM
bud-weis's Avatar
bud-weis
Football Cwazy
this could be a long thread........
Old Jul 15, 2006 | 06:49 AM
Alan s1's Avatar
Alan s1
BUSTED
Old Jul 15, 2006 | 07:05 AM
Paddy's Avatar
Paddy
Legend
BUSTED
BUSTED! That's the CD he always has on!
I saw him cry when they split up.
Old Jul 15, 2006 | 07:16 AM
Alan s1's Avatar
Alan s1
BUSTED
On top form this morning Paddy
Ps in my Case it was OIL LEAKS
Old Jul 15, 2006 | 07:20 AM
Eagle's Avatar
Eagle
Super Moderator
it was nevr a fuel consuption problem with alan .... his car did 40 mpg ... of oil
Old Jul 15, 2006 | 07:22 AM
Alan s1's Avatar
Alan s1
so True
Ps Pete you on Msn ??? need to ask a Q on Abs on a cossie
Old Jul 15, 2006 | 07:23 AM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: cosworths most common faults
Define your question more clearly please as in all honesty, they dont actually have many common "Faults" at all. It is a VERY fault free car and extremely over engineered.
Most YB Cosworth problems are down to the owners and poor maintainance.
Old Jul 15, 2006 | 07:28 AM
Paddy's Avatar
Paddy
Legend
Old Jul 15, 2006 | 07:31 AM
stonehavencossie's Avatar
stonehavencossie
this is the funniest question ive ever heard on here
how longs a peice of string ................................................
But as said all faults are down to owners (previous) abuse
Old Jul 15, 2006 | 08:34 AM
Mike1's Avatar
Mike1
Track control arm bushes tend to go quite often ...............but that's true for most Sierras. Poly one are a good upgrade
Old Jul 15, 2006 | 08:35 AM
Speedy Gonzalez's Avatar
Speedy Gonzalez
3 years of cossie ownership and no problems whatsoever
if there well looked after maintain regularly you won't have any problem with them at all
like Stu said most cossie problems are down to the owners and poor maintainance
Old Jul 15, 2006 | 08:37 AM
sabres74's Avatar
sabres74
Faults. What faults.
Old Jul 15, 2006 | 08:41 AM
daz1968's Avatar
daz1968
The only common faults I have been told to look out for are loom plugs and connectors and the fuseable links, as they are getting old now. When all my electrics are turned on the fuseable links get hot, have been told to cut them out and replace with fuses, but forgot what rating to use. But as I don't use the car in bad weather then I won't have all electrics on anyhow so should be ok.
Old Jul 15, 2006 | 08:49 AM
pee vee's Avatar
pee vee
RUST if they aint looked after properly!!!
(took me a while to find a good one!)
If 4x4s have standard brakes and aint good quality discs they can warp
fairly easy..
the engines seem Very good,
the gaskets do leak, but once replaced they seem ok!
but as Stu said, looked after they are pretty fault free
had mine a year and half, and the ONLY FAULT that saw it off the road
was when the battery died one day.
Old Jul 15, 2006 | 09:18 AM
Redkop's Avatar
Redkop
MT 75 gearboxes!
Old Jul 15, 2006 | 09:39 AM
Ginge !'s Avatar
Ginge !
just finding my feet
bank balance
Old Jul 15, 2006 | 09:46 AM
Speedy Gonzalez
Originally Posted by b19bal
bank balance
agreed!
Old Jul 15, 2006 | 09:47 AM
Ginge !'s Avatar
Ginge !
and they never seem to work proper when you take your mates out for a spin but run like a dream when your going to get some shopping
Old Jul 15, 2006 | 09:51 AM
Speedy Gonzalez
i've had that same problem!!!!!!
Old Jul 17, 2006 | 09:49 AM
foreigneRS's Avatar
foreigneRS
Testing the future
fuse box melting for rad fans.
had this happen at the weekend just before going on the 'ring. managed to dig the terminals out of the molten mess and get another fuse in there so that the fans work again, but will have to replace it with a sub loom that i made up from an old abs loom
Old Jul 17, 2006 | 09:57 AM
gingeRS's Avatar
gingeRS
too true
ALL COSWORTHS DEVELOP FAULTS WHEN CARRYING PASSENGERS
Old Jul 17, 2006 | 10:17 AM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
The cosworth is a great car, well engineered and a record of wins in rallys longer than the 7 bridge, however when it comes down to the owners and the upkeep, now we are talking about problems.............
Old Jul 17, 2006 | 10:30 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The most common problem is too much boost and not enough fuel .
Old Jul 17, 2006 | 10:48 AM
ECU Monitor Enthusiast
Mapping an engine without using det monitoring equipment of any kind
Old Jul 17, 2006 | 10:55 AM
Mike Rainbird
Caraholic
You're shitting me? There can be no-one THAT stupid surely? .
The DIVA's Avatar
The DIVA
Originally Posted by Cam
the owners
Got it in one.....
The single biggest Cosworth problem.....
Old Jul 17, 2006 | 11:28 AM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
erm diffs seem to be a bit of a issue for me
Old Jul 17, 2006 | 11:34 AM
Harris.'s Avatar
Harris.
Erm, water temp sender,crank sensor,map sensor,air temp sensor And i look after mine
Old Jul 17, 2006 | 11:36 AM
Porkie's Avatar
Porkie
Old Jul 17, 2006 | 11:39 AM
Rab's Avatar
Rab
Fucking superstar........
The fact they're a Ford
Old Jul 17, 2006 | 11:44 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Only ever had minor issues, they strong as fuck, just often bodged.
As per stus comment, most are issues to to bad maintainance and setup.
Missfires I used to get a lot.
Melting rad fan wiring in fuse box.
Clutch cable used to snap relativley often, but that was prob my fault
Umm, thats it really.
Old Jul 17, 2006 | 12:50 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
rear light wiring
Old Jul 17, 2006 | 01:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Originally Posted by JTECHSAFF
rear light wiring
that's all sierra's, not just cosworths
Alun Gregory
Sep 6, 2015 09:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
