big problem
this problem is on a FRST
hae just fitted a T3 to it, it won't start up, very thing connected, it has spark and fuel wen it's ment to get it, the wierd thing is if u take anyone of the spark plugs out it will run on 3 cylinder but it wont start on 4 cylinder
has anyone else had this problem or got any ideas as to what it is because i am stumped.
the only thing i can think of is it still has the same air filter that it did when it was running as T2, would this cause it to be starved of air??
cheers
marc
cheers
marc
Nope as my T3 converted FRST is still on the same filter as well and that goes fine. My guess is you've disturbed something you shouldn't have during the conversion. I would start by checking all the multi plugs out. The fact you have fuel and a spark would indicated the CPS isn't at fault
yea it starts wid any 3 of them linked up but u hav 2 hav the spark plug out of 1 of them for it 2 start, then if u put all plugs in etc it wont start, got me baffled
i really dont know why but it says to on that guide.im wondering whether it might be blocking the flow of exhaust gases cos u say it runs with a plug out as the compression is being let out of the plug hole rather than being trapped in the cylinder if it is blocked.do a compression test on all 4 cylinders and see what they are
ok kewl, jus wondered, it does it on any of the cylinders tho if you let a plug out m8, gonna put ERST gasket on tomorrow and see if it makes any difference.
the fuses are all good and so are the vacuum hoses m8, as i say tho it will run on any 3 of the cylinders but not on four of them and to get it 2 run on 3 you have to take da spark plug out to get it to run.
i really dont recommend this as i wouldnt do it myself but have you thouight of starting it on the 3 and sticking the 4th plug back in and reconnecting the ht lead?
tried that aswell and as soon as the plug gets in the hole it stalls the car m8, which is reli wierd, i mean i tried everything i can think of doin n still no where at the min,
was hopin someone would have some ideas i aint tried lol
cheers marc
cheers marc
hav tried it with and without the chip, we hav done a compression test and they all seem the same and seem to be fine in my past experience. yea battery has been fully charged.
its jus such a wierd problem and am reli stuck with it know lol
rite just had a word with my m8 its his car not mine and he says he cant understand why it wont start was fine untill we changed the turbo,
the engine itself is 5500quids worth of full steel low comp bottom end etc and has only done 6k since it was built, it was run in with no boost for 1.5k of that aswell
cheers
marc
cheers
marc
