hydrolic Lifters
Old Jul 12, 2006 | 06:24 AM
MMartin's Avatar
MMartin
Default hydrolic Lifters
finally putting my engine together and would like some advice on the lifters, whast the best way to prepare / fit them in order to make the dam things as quiet as possible...
ive heard a few people tell me to soak them in oil first then other saying dont do that...any advice would be great
Matt
Old Jul 12, 2006 | 12:18 PM
Rick's Avatar
Rick
The key is to make sure they are going in with a new cam, they are lubed with proepr cam lube, and then run in. I never bother saoking them in oil. They will fill up to there correct height within a few seconds on startup.
Old Jul 12, 2006 | 10:36 PM
MMartin's Avatar
MMartin
yeah there going in with a new kent cam
Old Jul 18, 2006 | 07:06 PM
As rick says dont even bother to soak them, what do these people think oil pressure is for ??
They may be noisy for a minute or two but so what, on certain vw's if you preload them with oil they will jack up as it cannot escape fast enough when started and pistons and valves have a fight!!
Old Jul 19, 2006 | 03:47 PM
MMartin's Avatar
MMartin
yeah there fitted now, still just as rattley at the mo, they should quiet down hopefully then
Old Jul 19, 2006 | 05:50 PM
I use WYNNS engine flush before every oil change and for noisy tappets I use WYNNS OIL CONDITIONER/STABILISER it works for me.
Got rid of 90% of my noise, my tappets have done 140,000 though.
RUBY123
Oct 22, 2023 12:04 PM
Roosie
Aug 13, 2015 07:40 PM
ray barker
Aug 7, 2015 09:00 AM
wardyxr2
Mar 31, 2005 06:18 AM
