not starting
Old Jul 11, 2006 | 03:41 PM
thelynx's Avatar
thelynx
Default not starting
Hey
Just had my engine put back in and we had it running but lumpy.. Went up to the garage today drove it in from the yard to sort the clutch but now it wont run, we checked the injectors and there not getting fuel? what could cause this so suddenly
Incorrect mixture?
Old Jul 11, 2006 | 03:48 PM
ballin's Avatar
ballin
fuel pump
Old Jul 11, 2006 | 04:00 PM
addiction's Avatar
addiction
how did you check for fuel at the injectors?
Old Jul 11, 2006 | 09:54 PM
thelynx's Avatar
thelynx
Originally Posted by ballin
fuel pump
We have fuel at the filter...
We disconected the injector lines from where they go in to the back of the engine and there was no fuel there
Old Jul 11, 2006 | 10:18 PM
NEWTON's Avatar
NEWTON
has the fuel pressure droped,cos there mecanical injectors and rely on fuel pressure so they wouldnt open check the fuel pump mate or put a presure gauge in the fuel line
Old Jul 11, 2006 | 10:50 PM
thelynx's Avatar
thelynx
Will try it in the morning
Old Jul 11, 2006 | 11:06 PM
gambit's Avatar
gambit
Default fuel
if you put the ignition on number two then you should hear the fuel pump priming if you cant then the pump is more then likely nackered. First check the fuse in the fuse box and the relay before forking out on a new pump.
Old Jul 11, 2006 | 11:17 PM
NEWTON's Avatar
NEWTON
good luck mate i think its your problem fro m what ive read cheers
Old Jul 12, 2006 | 01:46 AM
thelynx's Avatar
thelynx
Default Re: fuel
The fuel pump is def priming.. it does want to fire but only for half a second.. thing is this car was running this morning... the guy was fidling with the mixture to get it running better do you think hes fucked it up? what controls the ammount of fuel that goes through at the metering head?
Old Jul 12, 2006 | 07:54 PM
NEWTON's Avatar
NEWTON
Default Re: fuel
there should be a fuel pressure regulater
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
