confused?? petrol pump
Old Jul 10, 2006 | 03:22 PM
kurdt5's Avatar
kurdt5
Default confused?? petrol pump
this is the one i took of my S1
http://img.photobucket.com/albums/v4...dt5/s1pump.jpg
this is the replacement i was given....but it dont fit the pos and neg wires.
went to lucas for a pump and they had this one as the s1 pump aswell.
Is it a S1 pump??? cos i cant fit the bugger.
[img][/img]
Old Jul 10, 2006 | 03:45 PM
SafeChav's Avatar
SafeChav
You may need to change the terminals for ring terminals. The standard pumps have special ford terminals, so maybe the plugs are hard to obtain and were changed for a reason.....?
Old Jul 10, 2006 | 05:54 PM
XR2's Avatar
XR2
Ford was the only manufacturer that used the plugs. This is a fuel pump out of a Audi/VW/Porsche/Mercedes etc. with K-Jetronic and screwed. Just change your plugs and this will work fine!
Old Jul 11, 2006 | 11:26 PM
NEWTON's Avatar
NEWTON
Default Re: confused?? petrol pump
[img][/img]
you got the pump from me just change the terminals on your wiring to rings mate its fine mate cheers
Old Jul 12, 2006 | 10:28 AM
kurdt5's Avatar
kurdt5
i sorted it newton.......i had to change the wiring to get it on, the one i had was the standard one, your one was the upgrade.
works spot on bud
Old Jul 12, 2006 | 07:51 PM
NEWTON's Avatar
NEWTON
works spot on bud
nice one glad your happy mate
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
lime
Sep 25, 2015 06:56 PM
