View Poll Results: Whitch one have you used
Standard
11.11%
Group A
37.04%
Cosmetic
24.07%
Mountune
18.52%
Wire Ring
3.70%
Other Unknown
3.70%
Other Name Brand ????
1.85%
Voters: 54. You may not vote on this poll
Head Gaskets WHAT ONE HAVE YOU USED
Old Aug 13, 2004 | 10:55 AM
RS500/364's Avatar
RS500/364
Default Head Gaskets WHAT ONE HAVE YOU USED
Good Bad or Dont use?
Old Aug 13, 2004 | 10:56 AM
TIFF's Avatar
TIFF
Chasing Radders
Bet you cant guess
Mountune 4 Layer WRC jobbie
Old Aug 13, 2004 | 10:58 AM
zvhturbo's Avatar
zvhturbo
Ferriday copper
Old Aug 13, 2004 | 11:40 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Ive used:
Standard / wire rung / standard head bolts - with 385bhp (at peak 32psi held 26psi), the gasket would lift and start to show signs of failure every 8k to 20k, depending on number of track days in year (most was seven resulting in 8k).
Mountune / long studs - 419bhp (at peak 34 psi held 26psi) and 515bhp (at peak 34psi held 32psi) - NEVER had a gasket failure.
Old Aug 13, 2004 | 11:44 AM
Karl's Avatar
Karl
Norris Motorsport
I've had every type of gasket fail for various reasons. The only type I've not had fail through the gasket quality alone is a mountune WRC, but I have had them fail on engines where the block deck has suffered corrosion and hence has'nt been 100% flat, or the engine has been overheated.
Old Aug 13, 2004 | 12:01 PM
Garage19's Avatar
Garage19
I used a COSMETIC one. It looked very pretty, but did fook all for sealin me head to me block!
I think you mean Cometic?
Old Aug 13, 2004 | 12:02 PM
Matt's Avatar
Matt
a problem free mountune on mine
Old Aug 13, 2004 | 12:04 PM
cossymad's Avatar
cossymad
Yes I v'e seen these too
Old Aug 13, 2004 | 12:08 PM
St3V3_C's Avatar
St3V3_C
When I say standard I mean late EscCos one...
Stage 3
Old Aug 13, 2004 | 12:47 PM
Ian M500COS's Avatar
Ian M500COS
"Cosmetic".... I like that....that's funny!!!
Old Aug 13, 2004 | 01:04 PM
turbinator's Avatar
turbinator
4 layer wrc ... same as mountune.. only the price where I get them is a lot better.. :P 210 pounds and loads left
Old Aug 13, 2004 | 01:09 PM
Rene's Avatar
Rene
tell me more
Old Aug 13, 2004 | 02:01 PM
rstoughy's Avatar
rstoughy
Genuine Mountune 4 layer WRC. Never had a problem.
Old Aug 13, 2004 | 02:10 PM
turbinator's Avatar
turbinator
tell me more
simple.. i have them on stock , everyone needs them sooner or later
Old Aug 13, 2004 | 02:41 PM
ricky's Avatar
ricky
so could you used 4layer wrc gasket on a wire
wrung block
Old Aug 13, 2004 | 04:24 PM
Jon(m600)'s Avatar
Jon(m600)
mines got a coopers ring gasket which as only been on a year and its already fooked.
Old Aug 13, 2004 | 05:23 PM
Karl's Avatar
Karl
Norris Motorsport
LOL @ coopers ring gasket. They're definately a no go these days!!!
Old Aug 13, 2004 | 05:27 PM
SteveB's Avatar
SteveB
When I rebuld next year i'll be going the wire rung/YB1261 gasket/std bolts route.
I have however had...... std and wire rung, grp A, wire rung with std gasket and long studded......
Old Aug 13, 2004 | 05:31 PM
B11GNS's Avatar
B11GNS
Grp A
Old Aug 13, 2004 | 05:34 PM
Rhys's Avatar
Rhys
i will be using a cometic one
Old Aug 13, 2004 | 05:37 PM
dave green's Avatar
dave green
WRC 4 LAYER LAMINATED All the time
Old Aug 13, 2004 | 05:49 PM
alan rainbow's Avatar
alan rainbow
wire rung with a 611 had no problems
Old Aug 13, 2004 | 05:53 PM
Jon(m600)'s Avatar
Jon(m600)
whats involved in sacking off my coopers ring gasket or am i stuck with it
Old Aug 13, 2004 | 06:20 PM
tkrath's Avatar
tkrath
Grp. A and no problems with it the last 50.000 km.
/Thomas Krath
Old Aug 13, 2004 | 06:41 PM
SPADGE's Avatar
SPADGE
Corn flake packet works a treat
Old Aug 13, 2004 | 06:53 PM
kjc300's Avatar
kjc300
I was thinking about getting the rings ground down to block height and then using a conventional gasket!!!! Not sure if it work ok but I don't see why not!! Bit cheaper than decking the block and fitting lower comp pistons (may as well be a rebuild if you're going to do that, and if you're going to do that you may as well get a new block!!) I'm in the same boat!!
Old Aug 13, 2004 | 07:47 PM
Deano's Avatar
Deano
Cometic for me
Mine done me well proud
Old Aug 13, 2004 | 08:07 PM
DazC's Avatar
DazC
PMSL at Cosmetic!!
Old Aug 13, 2004 | 08:23 PM
Smit's Avatar
Smit
The 60ft Launch King
i got a Group A jobbie
Old Aug 13, 2004 | 09:04 PM
Damo V's Avatar
Damo V
My Cometic (thicker of the two available) has been on my car for a while now, though the block was blueprinted 30k before I fitted it, its been sweet, previously had a group A which lasted about 30k
Old Aug 14, 2004 | 05:25 PM
Alg1k's Avatar
Alg1k
WRC
Old Aug 14, 2004 | 05:53 PM
saphycozzie-adz's Avatar
saphycozzie-adz
dont scimp.....WRC all the way
Old Aug 14, 2004 | 06:13 PM
peteh's Avatar
peteh
Originally Posted by TIFF-C20WTH
Bet you cant guess
just found out much these are
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
