Head gasket gone!!!!! Best 1 t replace with????
Old Jul 5, 2006 | 09:06 AM
Big D's Avatar
Big D
Default Head gasket gone!!!!! Best 1 t replace with????
Got a stage 3 cossie with all the bits
t4 turbo
grey injectors,
rs500 cooler
forged pitons
However only a standard 205 block ie not wire rung or long studded etc.
Whats the best gacket to use??? Not long ago put a metal cometic 1 on but only lasted 6000 miles
Its not mega mega power
Peaks at say 31psi and holds at around 27psi!!!!
Dave
Old Jul 5, 2006 | 10:19 AM
bud-weis's Avatar
bud-weis
Football Cwazy
that's not stage 3 then!!!
i'd use mountune 4 layer WRC gasket,Ł375 but never heard of one fail!!
BUT you must make sure the head and block faces are PERFECTLY flat with any metal gasket
Old Jul 5, 2006 | 10:49 AM
IANS2RST's Avatar
IANS2RST
just use a group a reinz gasket & a set of genuine headbolts.
my 4x4 running 26 psi has had 1 on for the last 4 years & i've done 3 track days & loads of 1/4 mile days since I've had the car in the last 14 months with no problems.
as above though if u use a metal head gasket both the head & block need to be perfeclty flat which will probably mean a engine out & full strip down as the block will have to be machined as well as the head.
Old Jul 5, 2006 | 11:21 AM
Staffi's Avatar
Staffi
Default Re: Head gasket gone!!!!! Best 1 t replace with????
t4 turbo
grey injectors,
rs500 cooler
forged pitons
Dave
That spec brings a whole new meaning to stage 3
Old Jul 5, 2006 | 04:18 PM
jon@work's Avatar
jon@work
This spec will be OK for your engine spec, Ian, but not good enough for a T4 blowing 30+psi
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
