2 stage ECU
Old Jul 5, 2006 | 12:52 AM
Hyper's Avatar
Hyper
Default 2 stage ECU
How much do these cost, and particular ones that are better. Can you set the 2 boosts settings at whatever you like. How do these work techicanlly. I know a bleed valve just blows out some of the air. Im thinking thats pretty pants !
Old Jul 5, 2006 | 08:11 AM
reality's Avatar
reality
Not sure what you mean by a stage 2 ecu..
If you get a proper rs turbo chip, then this will be able to see up to about 1.2-1.3 bar correctly.. having different boost levels is up to you really, it's pretty simple to have low/capsule boost (eg, 10-12 psi) and high boost (up to 23 psi) just by putting a switch on the amal valve..
Old Jul 5, 2006 | 08:34 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I used to have 2-stage boost, back in the day!!
I NEVER used to use the low boost setting. Have it set up for the maximum boost it can safely run, then if you don't want full boost, then don't stick your toe all the way down.
Old Jul 5, 2006 | 09:03 AM
HORNETS7's Avatar
HORNETS7
put a switch between the amal valve and earth
it will half and double the desired boost but as said above adjust your actuator to get maximum boost level first
this way it wont boost beyond your maximum boost level!
Old Jul 5, 2006 | 09:28 AM
reality's Avatar
reality
Adjusting actuator arms to control boost is a bad thing.. half a hole of preload is what you want, then you jet your amal valve to achieve the desired max boost..
Old Jul 5, 2006 | 11:05 AM
Hyper's Avatar
Hyper
Thanks peeps.
Old Jul 5, 2006 | 03:56 PM
addiction's Avatar
addiction
what? that is how you adjust the boost correctly,by preloading the actuator!
and what if you dont even run with an amal valve?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
griffo69
Oct 4, 2015 11:58 AM
