how much boost can u run on ofac or ofab
Old Jul 3, 2006 | 06:57 PM
2litresi's Avatar
2litresi
Default how much boost can u run on ofac or ofab
hello i no there is a difference in map sensors between ofac and ofab can u put a 3 bar straight on ofab.
what size map sensor are they 2 bar 2.5 bar
just need to no if u could run more boost then the other
thanks
Old Jul 3, 2006 | 07:29 PM
jrs's Avatar
jrs
You can only run 1bar of boost on ofac ofab you can run more
Old Jul 3, 2006 | 07:31 PM
Rab's Avatar
Rab
Fucking superstar........
OFAB is a weber map sensor, so you can swap for a 3 bar (absolute) and run 2 bar positive pressure. OFAC is the ford type map sensor, and you can run 1 bar positive, but apparently this is a software issue and can be worked around to enable you to run +1.5bar. Speak to Stu@MSD as he'll be able to give you better answers than me
Old Jul 3, 2006 | 08:40 PM
Oranoco's Avatar
Oranoco
As Rab says the OFAC issue is a software not a hardware one.
Old Jul 3, 2006 | 09:12 PM
mint rs's Avatar
mint rs
JK12
33
Apr 26, 2021 12:09 PM
dombanks
Sep 21, 2015 08:38 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
