efi conversion
Old Jun 29, 2006 | 03:05 PM
TURBO BOI's Avatar
TURBO BOI
Default efi conversion
Ive put on the sierra crank pulley and this is how the teeth line up against the cps sensor, good enough? or does the teeth have to be spot in the middle of the cps sensor to read it?
throttle cable bracket, mine hits the lower part of the mainifold, is it on the right wasy round? or shall i cut the bracket?
Old Jun 29, 2006 | 04:10 PM
SafeChav's Avatar
SafeChav
As long as the cps is near enough central it will be fine, they are very wide teeth on that pulley after all.
Which part of the bracket hits? I presume you do know the bottom lug is meant to go over the thread before the nuts holding the manifold on are tightened to the head?
Old Jun 29, 2006 | 05:20 PM
TURBO BOI's Avatar
TURBO BOI
ive got a adapter plate on mine between the mainifold and the head so the mainifols sits back further so the lug wont sit on the thread, guess il have to chop it
Old Jun 29, 2006 | 07:09 PM
SafeChav's Avatar
SafeChav
oooooooohhhhhh, now i get you. There are 2 types of throttle bracket, i believe the later ones mount from the top and side so that will sole your problem
Be better than cutting yours IMO
Old Jun 29, 2006 | 07:11 PM
TURBO BOI's Avatar
TURBO BOI
oh wkd didnt know there were to types of bracket
Ive cut mine now
Old Jun 29, 2006 | 07:14 PM
SafeChav's Avatar
SafeChav
Indeed there is, the later ones are less interfering with the injectors etc aswell, get the bracket do it properly
That said.....yours should still still fit behind the nut, it shifts the whole manifold back
Unless there isn't enough thread.....
Old Jun 29, 2006 | 07:18 PM
TURBO BOI's Avatar
TURBO BOI
i had some dodgy threads on it, there were all too short so i replaced them with some rover k series ones i had it the garage, these are long enough but not to have that bracket aswell, il get the other type bracket when its up and running
Old Jun 29, 2006 | 07:19 PM
SafeChav's Avatar
SafeChav
The last thing you want is the throttle bracket moving and jamming fully open.........
Old Jun 29, 2006 | 07:22 PM
TURBO BOI's Avatar
TURBO BOI
its got 2 other bolts holding it, sure be ok untill i get another 1 i hope
Old Jun 29, 2006 | 07:25 PM
SafeChav's Avatar
SafeChav
Blu-tak?
Old Jun 29, 2006 | 07:29 PM
TURBO BOI's Avatar
TURBO BOI
Blu-tak?
good thinking
running efi on the cabby?
Old Jun 29, 2006 | 07:59 PM
SafeChav's Avatar
SafeChav
They don't call me brains for nothing
Will be..........if i ever pull my finger out
Old Jul 1, 2006 | 07:00 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Old Jul 8, 2006 | 04:46 PM
TURBO BOI's Avatar
TURBO BOI
how can i get the crank pulley tight? wana tighten it up, ive put it in gear but the engine still turns over when i try to tighten it
Old Jul 8, 2006 | 08:12 PM
SafeChav's Avatar
SafeChav
The way i usually do it, is put the car in gear with the handbrake yanked up, the engine will turn over a little until all the gears in the box mesh up tight etc, but thats the way.
Not a lot of space to get a ratchet in there is there
Old Jul 8, 2006 | 11:49 PM
TURBO BOI's Avatar
TURBO BOI
not to bad with the engine jacked up with out the mount on, i can get a ring spanner in there
Old Jul 9, 2006 | 12:06 PM
Versus_Creations
Ask me a question!
So you are using the cam belt to hold the crank while yanking on a spanner. Nice one
Good advise..
Or you could lock the flywheel up from the starter motor hole.
Old Jul 9, 2006 | 12:58 PM
DazC's Avatar
DazC
Jano,
He asked about tightening the crank pulley mate, not the cam pulley.
Old Jul 9, 2006 | 01:13 PM
SafeChav's Avatar
SafeChav
Originally Posted by DazC
Jano,
Ditto, reply was a bit sarcy don't you think.......
Old Jul 9, 2006 | 01:48 PM
Versus_Creations
Ask me a question!
Which is why is was a question?
If the engine is in gear, with the head on...
Then trying to tighten pulley bolt will turn engine just a little before it locks up. If on the off chance the cam has stopped in the wrong position you could damage the valve. However small the chances are. There is still a chance which i wouldnt want to take, either on my own engine or customers.
HTH
Regards
Jano
Old Jul 9, 2006 | 01:51 PM
SafeChav's Avatar
SafeChav
So now you are talking about the bottom end spinning over and hitting a valve because there is no cam belt on.....
Old Jul 9, 2006 | 02:16 PM
Versus_Creations
Ask me a question!
At the end of the day its as simple as this.
Bottom bolt is done up while locked by flywheel.
Old Jul 9, 2006 | 02:18 PM
SafeChav's Avatar
SafeChav
Once again you have avoided the question
Yes locking the flywheel is one way of doing it
Old Jul 9, 2006 | 02:29 PM
Versus_Creations
Ask me a question!
Andy i have better things to do than answer all your questions.
I am offering advise that is 100% without fail or chances of failing!
Locking the flywheel (Via teeth) or crank (Via flywheel bolts) is the only way the bottom pulley bolt should be done up.
Not while the car is in gear, or any other way.
Old Jul 9, 2006 | 03:27 PM
DazC's Avatar
DazC
Lads, he asked how to tighten the bolt holding on the CRANK PULLEY. The timing belt is driven by the TIMING GEAR, not the CRANK PULLEY. A locked crank is a locked crank, however you do it.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
