Boost gauge question
Old Jun 29, 2006 | 01:05 PM
cosrep's Avatar
cosrep
Default Boost gauge question
Could I take a feed off the map sensor to supply a signal to a electronic boost gauge and if so would any one know which of the three terminals to use?
Old Jun 29, 2006 | 02:18 PM
reality's Avatar
reality
Yeah, analogue MAP sensors give you a linear output relative to pressure from say 0.25v-4.75v full range.. The pin out will depend on which map sensor you're talking about!
Old Jun 29, 2006 | 03:10 PM
cosrep's Avatar
cosrep
My saff cos 4x4 is a stage one so still has the stanard cosworth map sensor.
Old Jun 29, 2006 | 03:16 PM
CosRush's Avatar
CosRush
As far as im aware, its best to avoid tee'ing into the map sensor. It is a very sensitive and important sensor, and as far as ive heard, by teeing into it you can affect its response such that it can cause running problems one of which may be running lean
Hopefully an 'Expert' will advise you better but i'd hold off until you know for sure..........
Old Jun 29, 2006 | 04:37 PM
reality's Avatar
reality
You should have everything on it's own source on the plenum..
But he's talking about electrically, not pneumatically
Old Jun 29, 2006 | 04:40 PM
CosRush's Avatar
CosRush
Oops my mistake......should have read it properly
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
Russ Payne
Sep 25, 2015 08:29 PM
