Saff Fuel line
Going to replace the main fuel lines on my brothers 4x4 Saff.
The return is no problem but the feed seems to have some sort of fancy plastic connector
how do i get this off the pipe?
Also, will i need to go to ford for the new feed pipe or can i make this up?
Cheers,
Paul.
Cheers,
Paul.
PassionFords Creator
Cheers,
Paul.
Cheers,
Paul.
Originally Posted by Stu @ M Developments
The cover needs prising off and underneath it is a standard pressure fit pipe, 8mm i recall. Just press the collar in and the pipe will pull off.
JK12
33
Apr 26, 2021 12:09 PM
