How much is mopping?
What would a mobile or local valeter charge to mop a car? obviously the exact prices depend on the amount of work involved but whats the best / worst cases prices I would expect?
i'll ask him see what he says, hes pretty good with scratches as his sorted out his brothers polo which was a right mess, that wing mirror looks like its gunna need paint.
you'll have to bring the car here though cos he wont go to slough
Waht exactly is "mopping"?
I've heard it mentioned loads of times -I presume it's where they use one of those machines and a cutting compound to remove the top layer?
Correct me if I'm wrong, as I don't know!
From the look of those scratches i doubt it could be done with a machine polisher. They look to have cut through the clearcoat and damaged the paint and primer. You possibly could improve the appearance of them but they would still be there.
But the results can be outstanding and is the next best thing to a respray.
just showed the pics to my mate and he said the same thing, it'll need paint as its gone down to the primer. he said he could try a stiffer pad on it see if it helps.
he'll do the car if you want but as said you'll have to bring it home.
these are quite cheap prices we're getting here!
I spoke to a valeting company in slough yesterday and without looking at the car they reckoned on about Ł140.
Look at what these guys achieved with a porter cable
http://guidetodetailing.com/imageview.php?imageId=89
http://guidetodetailing.com/imageview.php?imageId=84
http://guidetodetailing.com/imageview.php?imageId=92
http://guidetodetailing.com/imageview.php?imageId=87
The prices you've been quoted from valeters is about right imo, personally I would charge around Ł140-Ł150.
Some comapnys base it on about Ł20 per panel.
Judging by the pics, theres nothing you can do with the bad scratches might be able to hide them a bit but will still show.
The other light scratches you can get out if there not too deep.
Can do this by wet sanding with very fine wet and dry, and then compounding or maybe even just compounding if they are very light scratches.
Yes the work was done by me with a porter cable. Would be a lot quicker with a rotary but the chance of cocking it all up are also higher, you only need to look around the local BM showroom to see witness of that
The PC is actually quite easy to use if you do your homework and understand polish / pad combinations and the way a polish works / breaks down. The pannels in the photo's are not waxed, the photos were taken after the polishing step.
I believe that those pictures have found their way onto many forums now and I actually found one guy claiming the work was his
WD Pro, thats a top finish mate!! nice one.
Heres two pics of my rs 1800 after a quick mop. The paint was flat as it had been parked up for 6 months.
Smudge
Smudge
so if thats the finish after a mop, whats the next stage to keep it looking that shiney?
wax on wax off danial-son?
or is there another trick?
i can see you getting loads of work in the run up to ford fair
Originally Posted by Taz
so what IS a porter cable then????
I know what a buff is as I have one of those.
Graham
Graham
Anyone got any pics or info please
Cheers, Smudge
(I know its of the wheel but look at the wing)
The key to keeping them that way is good maintenance A automated car wash or dirty sponge will spoil it in weeks.
Once in good nick they are relatively easy to maintain. I did a guys (black) Audi about 10 months ago, gave him some tips and recommended products for him to use (after knowing how much / long he was prepared to spend looking after it) and the car still looks great now.
WD
so, in this order
mop
wax
and then just keep waxing
and cleaning, with a clean cleaner sponge
have i missed anything out?
mop
wax
If cared for correctly and washed 'with' care at least weekly its possible to :
YEARLY - 1-2 Days - De tar, clay, machine polish, hand polish then hand wax.
Followed by :
MONTHLY - 1/2 day - Hand polish then hand wax.
Followed by :
WEEKLY (or more) - 1 hour - wash.
The odd 'touch' up could be needed in between i.e. bird shit, bad tar from road works etc.
The key to good maintenace is good (i.e. non scratching) regular washing so contaminents dont have time to stick (requiring clay).
Use a good wash mit (lambs wool) and use two buckets (one for clean wash, one for flushing the mit) or use one bucket with a grit guard.
Loads of stuff has been written about methods before on places such as autopia. Have a look and find one that suits your time, budget and level of finish you expect.
Bear in mind that the color, type and age of paint on your can can vary its maintenance needs vastly.
On a soft water based clear coat a freshly polished surface would pick up fine scratches from just brushing past it with with jeans or similar. Not allways visable to the average person but doesnt half do your head in when youve spent a day polishing
On the other hand my GF has a silver Puma and you could wash that with a brick and it still look OK
I think you can still download a stunning 'how to' guide from the Autopia site. Careful though it soon becomes a addiction
Fookin lovely shine on that Golf
WD Pro - Do you do it for a profession? Metalic mop would look fookin smart
Also is Harley Wax any good? Heard stories it fantastic!
I only detail part time to make a bit of pocket money. The trouble is its time consuming and spare weekends are limited due to other projects
What do you mean by Metalic Mop ?
I believe the trade name for the Harley wax is S100 which is rumoured to be identical to P21s but cheaper as the bikers wouldnt pay for a car wax. I have a pot of S100 and it seems very good on blacks, blues and purples i.e. dark colurs.
I am inclined to believe the rumours as the P21s and S100 pots are the same colour and size and even use the same text fonts / labelling. If your off to the states you can pick it up even cheaper
Cheers,
WD
so, in this order
mop
wax
mop
wax
Followed by :
Followed by :
i might have to find you on one of your quite weekends and see if you wouldn't mind exchanging a few quid for your services
but it probably wouldn't be until the end of the year, so plenty of time to get the paintwork painted first
Matt Baxter
Concours d'élégance.
15
Feb 28, 2009 08:46 PM
