rs 500 t4 with a 48 back housing
Old Jun 26, 2006 | 09:47 AM
abdr500's Avatar
abdr500
Default rs 500 t4 with a 48 back housing
hi a rs 500 t4 with a ar 48 back housing would 400 bhp be its limmit because of the back housing
Old Jun 26, 2006 | 09:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
A 5litre V8 would possibly be its limit because of surge.
Old Jun 26, 2006 | 09:50 AM
Jay,'s Avatar
Jay,
Sponsor
Stavros's Avatar
Stavros
DEYTUKURJERBS
It will be surge-tastic
400bhp seems a lot for a .48 housing too, would have mental backpressure.
Shittest combo ever IMO
Old Jun 26, 2006 | 09:54 AM
abdr500's Avatar
abdr500
so a 63 would be a better
Old Jun 26, 2006 | 10:17 AM
DaveAVT's Avatar
DaveAVT
A .48 housing won't fit on a real RS500 T4..
Old Jun 26, 2006 | 11:17 AM
GARETH T's Avatar
GARETH T
Old Jun 26, 2006 | 11:20 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Old Jun 26, 2006 | 11:21 AM
GARETH T's Avatar
GARETH T
Old Jun 26, 2006 | 11:23 AM
why not?
Old Jun 26, 2006 | 11:32 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Old Jun 26, 2006 | 11:35 AM
DaveAVT's Avatar
DaveAVT
why not?
Turbine wheel is different.
Old Jun 26, 2006 | 11:37 AM
abdr500's Avatar
abdr500
why all the remarks i was asking a question
Old Jun 26, 2006 | 11:39 AM
abdr500's Avatar
abdr500
DaveAVT
your right it wount .its a t4 comp housing and comp wheel and back plate bolted on a t3 with a 48 back housing
Old Jun 26, 2006 | 12:30 PM
why not?
Different to what?
And how does the fact its different to something stop a .48 housing from being available for it too?
Old Jun 26, 2006 | 12:34 PM
SPADGE's Avatar
SPADGE
This will no doubt be why your asking the question?
http://cgi.ebay.co.uk/Cosworth-Garre...QQcmdZViewItem
Old Jun 26, 2006 | 12:39 PM
jon foz's Avatar
jon foz
i take it he only means a .48,we usually associate on the cosworth engine wont physically fit as the T4 on the RS500 has a much larger diameter exhaust wheel i have tried the combination he has mentioned,basically a T3 style turbo with an RS500 compressor on and never had any results worth writing about,thats my opinion anyway
f@ck it,put it on,at least it will look good
jon
Old Jun 26, 2006 | 05:03 PM
abdr500's Avatar
abdr500
ok any more info on using it with a 63 back housing
Old Jun 26, 2006 | 06:15 PM
DaveAVT's Avatar
DaveAVT
why not?
Different to what?
Different to the other 99% of cars that all use the same 59/48 T3 turbine, saabs, volvo, renault, ford, buick etc....
The turbine in the RS500 is a T31 HL wheel, larger exducer, heavier trim. They never made 0.48s to fit this wheel, as it was a mainly motorsport application - 0.63s upwards... The same unit was used on the Renault 21 Europa Cup cars...
Any more questions???
Old Jun 26, 2006 | 06:16 PM
DaveAVT's Avatar
DaveAVT
..so, any 'RS500' style turbos you see with 0.48's are simply Cosworth 2wd turbos fitted with a T4 cover, backplate and comp wheel...
Old Jun 26, 2006 | 07:47 PM
abdr500's Avatar
abdr500
DaveAVT
so will the t4 front end be ok with a 63 back housing .its got to be better than a t34
Old Jun 26, 2006 | 07:51 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
my magical hands can make a t4 shaft fit a .48 cos housing
Would be a waste of time though
Old Jun 26, 2006 | 08:34 PM
DaveAVT's Avatar
DaveAVT
Originally Posted by abdr500
DaveAVT
Yes, it will be roughly the spec of a T38..
3drRich
Sep 13, 2015 07:32 PM
ekjim
Aug 17, 2015 08:57 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
