FAO Dojj, Bernie, MOB or other gearbox bods......
Old Jun 25, 2006 | 01:57 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default FAO Dojj, Bernie, MOB or other gearbox bods......
How easy is it to remove the front case on the MT75 gearbox?
I need to swap the front case on my 2wd MT75 gearbox for the front case off my 4x4 mt75 gearbox.
If its easy enough, i'll do it myself, If not, i'll spend some money at a transmission service place
cheers
Old Jun 25, 2006 | 03:58 PM
markk's Avatar
markk
very easy to strip - if you have the tools
Old Jun 25, 2006 | 04:19 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Don't need to strip it Mark - only want to swap the front cases over,
Old Jun 25, 2006 | 04:39 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you just need to find a socket for the input shaft surronding ring thing (don't know what it's called though)
once thats sorted you just undo the bolts around the outside of the centre line, one that holds the reverse gear idler cog and then just prise them apart
BUT
you will need to remove the cogs to swap over the input shaft so it's not as simple as you might think
i'm sure someone will come along with the corect sized socket you need, but when i enquired about getting one i was quoted Ł300 so i used a screwdriver as a drift and a hammer to knock it round via the clutch lever hole in the bellhousing
Old Jun 25, 2006 | 05:05 PM
markk's Avatar
markk
you will be practically stripping the box believe me
Old Jun 25, 2006 | 05:09 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Dojj - the input shaft is the same length, i've measured them
its litrally ONLY the case that needs swapping
Old Jun 25, 2006 | 05:24 PM
dojj's Avatar
dojj
in that case, the pics are up in your other thread
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
