cosworth 2wd hydraulic clutch conversion
Old Aug 11, 2004 | 10:40 AM
thebigyin's Avatar
thebigyin
Default cosworth 2wd hydraulic clutch conversion
can anyone tell me who does them and how much?
Old Aug 11, 2004 | 10:41 AM
3drstretch's Avatar
3drstretch
I beleive Mr Hadland is the man.
Old Aug 11, 2004 | 11:03 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Reyland motors - £400 for complete kit (inc modifying your bell-housing on an exchange basis).
RichardPON's Avatar
RichardPON
Martin is the man for these sort of things.
Mine will be going there for the conversion after xmas........
Old Aug 11, 2004 | 02:32 PM
Uncle Henry's Avatar
Uncle Henry
what does it do for the force required to operate it?
I mean does it make a paddle clutch feel more like a normal one?
and is that £400 fitted?
Old Aug 11, 2004 | 03:26 PM
johncossie's Avatar
johncossie
and how much power can it take
Old Aug 11, 2004 | 03:28 PM
CabrioTurbo's Avatar
CabrioTurbo
anyone mind explaining the benefit of a hydraulic clutch?
CheeRS
Phil
Old Aug 11, 2004 | 04:19 PM
Mike Rainbird
Caraholic
No £400 is supply of the parts only for a 2wd, is cheaper on a 4x4 as the bell housing doesn't need modifying by Martin, it can be done by anyone with a drill.
The clutch plate and cover denote power capability, not how it is actuated .
Hydraulic actuation removes the hit and miss operation of the standard cable / ratchet mechanism. Gives a lovely feel to the peddle and more importantly self adjusts properly to remove any wear from dragging etc.
The standard ratchet mechanism isn't really up to the job of taking the force that the paddles require and can drag or worse snap the ratchets / stretch the cables.
Old Aug 11, 2004 | 04:22 PM
Ima-Racing500's Avatar
Ima-Racing500
I never had any problems with a cable and 6 paddle h/duty.....
Old Aug 11, 2004 | 04:25 PM
Mike Rainbird
Caraholic
Phil, you don't count, as you drive like a bufty, don't do track days and Santa Pod is not your scene .
Also, how many miles did you do with your 6 plate paddle and what power level?
Old Aug 11, 2004 | 04:30 PM
thebigyin's Avatar
thebigyin
i want it cos city driving is a nightmare with the paddle clutch
Old Aug 11, 2004 | 04:33 PM
Ima-Racing500
Jon......the alcon 6 paddle with h/duty cover is excellent for town work/launching etc etc using a std cable.
Old Aug 11, 2004 | 04:34 PM
thebigyin's Avatar
thebigyin
thats what ive got ,i find it shit in traffic
Old Aug 11, 2004 | 04:35 PM
Ima-Racing500
Really?I found it as good as the std clutch!..LOL.
Old Aug 11, 2004 | 04:38 PM
Gav Diamond's Avatar
Gav Diamond
Steve Scott also does this conversion.
Worth a call.
Mike Rainbird
Caraholic
Jon,
When the clutch was fitted, did you have the flywheel surface ground?
Old Aug 11, 2004 | 04:40 PM
thebigyin's Avatar
thebigyin
no mike i didnt,was ground about 6k before i fitted the alcon,maybe should of done it again?
Old Aug 11, 2004 | 04:41 PM
thebigyin's Avatar
thebigyin
ill give them both a bell and see whats what
Old Aug 11, 2004 | 04:43 PM
Ima-Racing500
Jon.....you did need the flywheel ground!..6k is enuff to fook it..thats your problem by the looks.
Old Aug 11, 2004 | 04:45 PM
thebigyin's Avatar
thebigyin
its still too much effort for city driving though,the hydraulic is easier on the leg so id rather have that
Old Aug 11, 2004 | 04:48 PM
Mike Rainbird
Caraholic
Yep, flywheel must be ground EVERY time a paddle is fitted. This is because the normal slipping of the clutch process will cause hot spots on the flywheel, which are slightly raised and the paddle will grab onto these when a new one is fitted. This makes it difficult to get into first gear and makes the car a pig to drive etc.
Old Aug 11, 2004 | 05:22 PM
thebigyin's Avatar
thebigyin
thanks lads
Old Aug 11, 2004 | 05:25 PM
Uncle Henry
so hydraulic is easier on the leg then? just asking as the next cos will need a paddle clutch and the missus will be driving it and I dont want her to have one man size leg and one girlie leg
Old Aug 11, 2004 | 07:49 PM
Ish's Avatar
Ish
reyland hydraulic clutch conversions :-
http://www.reyland.co.uk/Parts.asp?ID=4
Old Aug 11, 2004 | 09:13 PM
thebigyin's Avatar
thebigyin
thanks ish
Old Aug 11, 2004 | 09:21 PM
marco polo's Avatar
marco polo
I have a hydraulic clutch , i am useing AP racing heavy duty clutch cover , and an alcon 6 plate paddle clutch.
the feel of the pedal is lighter than a 1.1 fiesta it's that soft you wouldn't even think that you had a heavy duty clutch in the thing
shows you how much Ima knows, what do you expect form a buffty road racer
Old Aug 11, 2004 | 09:36 PM
thebigyin's Avatar
thebigyin
thats what im after
Old Aug 11, 2004 | 10:09 PM
Moose 130's Avatar
Moose 130
McCleod make a hydraulic release bearing/Slave cylinder for the T5's used in Mustangs.
Maybe its usable in the Cossie T5's and would make the swap easier.
Old Aug 11, 2004 | 10:45 PM
Ima-Racing500
Eh Marco you must be a wimp then..ROFL...opps sorry i know you are
How can you want a better feel than a STANDARD RS Cosworth clutch?
Old Aug 12, 2004 | 08:27 PM
marco polo's Avatar
marco polo
you obviously don't know then ,do you
light as fook
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
ray barker
Aug 7, 2015 09:00 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
